Hi All, Sorry for all the questions. 've got most things to work, such as the DVD which is a cool retro feel. Any tips on getting the HDD audio to work - I've uploaded music from USB onto the HDD, but when I select to play it is blank. Is there a how-to? Cheers.
Option 1: USB Drive (most reliable) Locate the USB port Usually found in the glove compartment, center console, or beneath the armrest (depends on trim). Format your USB drive Use FAT32 format. Store music files as MP3, WMA, or AAC (check your owner’s manual—FLAC and WAV often won’t read). Load your music Keep file names simple (avoid special characters). You can organize in folders, but keep the folder depth shallow (1–2 levels). Insert the USB Turn on the car’s ignition. Press the MEDIA button on the infotainment system. Choose USB as the source. Browse and play your tracks. Option 2: Bluetooth (only on later 458s or with optional module) Go to Settings → Bluetooth on the infotainment screen. On your phone, enable Bluetooth and pair with “Ferrari 458.” Once paired, select Media → Bluetooth Audio. Play music from your phone’s app (Spotify, Apple Music, etc.). ⚠️ Earlier 458s (2010–2013) did not include Bluetooth audio streaming — only phone call support. If yours doesn’t show a “Bluetooth Audio” option, you’ll need to use AUX or USB. Option 3: AUX Input Plug a 3.5mm AUX cable into the AUX port (often next to the USB). Set the infotainment source to AUX. Play audio from your phone or media player. Option 4: SD Card (if equipped) Some 458s with the premium navigation/audio unit include an SD card slot: Insert an SD card (≤32GB) with MP3 files. Select MEDIA → SD Card on the display.
Thanks - this is the bit I get stuck: Insert the USB Turn on the car’s ignition. Press the MEDIA button on the infotainment system. Choose USB as the source. Browse and play your tracks. There's nothing to browse - maybe I need to look at the folder structure
It's not reading your files for some reason. Its a finicky system and a bit of a joke to be honest. Ferrari could have simply bought a system from Sony or someone else like Sony and had a workable system. I gave up on it and now use an FM transmitter which works with no problem but the sound isn't very good. If I remember correctly, the one time I was successful was leaving the car's ignition on for a long time. Don't forget too that your files have to be non-DRM protected. I used CD's I owned from the 1980's and 1990's to make the transferrable files.
