Head and neck restraints | FerrariChat
Discussion in 'Other Racing' started by dfrace, Jul 22, 2006.
  1. dfrace
    dfrace Karting
    May 6, 2006
    85
    Alabama
    Darren
    I made a commitment to myself to never skimp on safety while on the track; but I never got around to investing on a head and neck restraint system, mainly because I really didnt think it was necessary at my level (beginner). So far I am averaging a hard crash about 60% of the time out. My car is getting close to race condition again after the last wreck, and I want to have as much protection as possible next time out.
    My question is, can any of you who use a restraint system give me your opinions on HANS or Hutchens? I do not feel either one is more safe, so it really is a comfort / ease of use / ease of exit issue. The olds Hutchens system looks very cumbersome to me, but the newer ones look much better (Hybrid in particular). My main concern is getting out of the car when its upside down and engulfed in flames ( I dont have a door like some of you, its out the window for me), and how hard it is to put the gear on (I'm usually in a rush because our loudspeakers suck and I can never hear them call our group). Freedom of movement is not really an issue. I drive a dirt car (late model) and already can't see jack side to side, and barely out the front.
  2. b-mak
    b-mak F1 Veteran
    You might want to check out a sprint car forum.
    For road racing, HANS is the only way to go.
  3. Dr Tommy Cosgrove
    36,469
    Birmingham, AL
    Tommy
    You crash "hard" more than half the time you drive and you have been thinking that you really don't need the extra protection until you gain more experience?
  4. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    Crashing 60% of the time sounds like a demolition derby!
    I'd recommend the HANS device. Easy to put on, and comes of quickly in case of an accident. Is your helmet equipped for this?
  5. dfrace
    dfrace Karting
    May 6, 2006
    85
    Alabama
    Darren
    I just started this year, and havent been out many times (I will never be any good, just trying to learn and have fun). I have sat out the last 2 months due to the car being mangled after I got collected in another wreck. Its probably going to be the middle of August before I can get back out (No time to work on it). My original plan of putting around in the back and learning to drive before trying to race didn't work out. I discovered that no matter how much distance you put between yourself and the other cars, one can always find you and wreck you.
    I have not noticed a single driver at any of the tracks I have been wearing one. I know there are probably some that do, and I see the guys running the national series (outlaw) with them, but in my opinion they are for the most part non-existent in local saturday night racing. Not even everybody wears those neck brace collars (which is what I was using before).
    Tommy -- it sounds dumb to me now too, thats why I am asking this. Because of the low speeds (4/10 mile track), and the fact that pretty much nobody wears them, I didn't think it was really needed. As for "hard", I might be calling something hard that someone else might not. I have seen some really bad crashes where the car was a writeoff, that might be your definition of hard, thankfully mine have not been near that bad. I am calling it a hard lick when frame tubing gets bent or when it hurts.
    TopElement -- sometimes it is a demolition derby, first race I was in started 20 cars and 5 finished.
    b-mak -- I'll check that out, the big dirt forum I used to use recently switched to new software, erased all history, and all logins. I havent't posted there because its a pain to register and then they spam you with ads.
  6. fatbillybob
    Aug 10, 2002
    29,074
    socal
    #6 fatbillybob, Jul 23, 2006
    I know nothing about dirt cars but safety in general is a system. HANS is only part of that system and does one specific job. If you use that device it helps for one specific instance and hinders exit. HANS likes to hang on windownets. So you could design your windownets with the small gm seatbelt as a quick release. Set it up for top and bottom release so that if you are upright you release top and the net falls away. If you upsidedown you release bottom and the net falls away. This way you can reduce the potential for HANS snagging on exit. Get a good fuel cell the kind with rubber liner in a steel can like an ATL. Do not use the roto molded plastic cells like the JAZ cell. Make sure you use a proper rollover check valve not just a inverted tube mounted in your ventline because if the car is on its side the gas will still come out without a checkvalve. use the screw on cap on the cells instead of remote filler necks which can break off like the earnhardt jr. fire some years ago. Also set-up your car so that the fuel pump shuts off when the engine is off. braided stanless fuel hoses with AN connectors only prevents rip offs. All electronics should be shut off with one kill switch including brake lights. Firesystems should have steel lines vs the aluminium ones they always come with especially with all the crap that flys on a dirt track. Use carbon-x underwear to wick moisture away from the body to prevent steamburns in a fire. So there are a few things. Post some pics of your car safety system and we can give you some ideas.
    Here is what those gm seatbelt clips look like
  7. Whisky
    Whisky Three Time F1 World Champ
    31,975
    In the flight path to Offutt
    The original Fernando
    ask this question on www.4m.net it's a pretty big dlm website.
