360 - Head lights turning on issue | FerrariChat
360 Head lights turning on issue
Discussion in '360/430' started by joshtownsend, Aug 12, 2025 at 10:38 AM.
  1. joshtownsend
    joshtownsend Formula Junior
    Jul 12, 2007
    422
    H-town...TEXAS
    I am having an issue that is strange to me.
    When i go to turn on the headlights, only one will turn on, and the other will remain off. If i turn off the lights and turn them right back on, whichever light was off, will turn on and the other light will remain off. If i repeat the process, both might turn on, or they may change states again. eventually, both lights turn on and stay on for the night.
    My thoughts is there are relays that may need to be changed and there are getting old or bad contacts.
    Anyone else have this issue?
    i search for this issue but didn't bring much up..ofcoasre assuming i searched for the right phases.
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,566
    Charleston, SC
    Curt
    if they're HID the ballast or bulb might need replacing....
  3. Qavion
    Qavion F1 World Champ
    14,396
    Ian Riddell
    There is only one (column) switch contact and one relay for both L/R low beams, so it won't be a switch contact or relay if one headlight is coming on.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,974
    Isle of man- uk
    If it 1 switch for both, then check the earth on both sides
  5. Qavion
    14,396
    Ian Riddell
    For info, the headlight (low beam), headlight (high beam), side marker and turn light all share the same earth on their respective side (i.e. two earths for all the front lights).
