Head lights | FerrariChat
Head lights
Discussion in 'California(Portofino)/Roma(Amalfi)' started by CCMFF, May 2, 2020.
  1. CCMFF
    CCMFF Rookie
    Nov 2, 2019
    14
    Uxbridge Ontario
    Colin Mason
    Has anyone with a earlier model California noticed the little reflector crystals on the led lights falling out? The lights still work just the crystals a rolling around inside the light.
  2. CCMFF
    CCMFF Rookie
    Nov 2, 2019
    14
    Uxbridge Ontario
    Colin Mason
  3. HarryC
    HarryC Rookie
    Nov 14, 2018
    41
    Harry Chambi
    I have two rolling around in my headlight, 2011 California.
    CCMFF likes this.
  4. Mohamed Haider
    Mohamed Haider Rookie
    Mar 21, 2020
    32
    Massachusetts
    Mohamed Haider
    Haven’t seen that yet... [emoji848]
  5. CCMFF
    CCMFF Rookie
    Nov 2, 2019
    14
    Uxbridge Ontario
    Colin Mason
    Drives me crazy, apparently no fix other than replace.
  6. HarryC
    HarryC Rookie
    Nov 14, 2018
    41
    Harry Chambi
    Yup, no way to fix.
  7. Andrew Leather-Barrow
    Andrew Leather-Barrow Karting
    Oct 9, 2019
    105
    United Kingdom
    Thinking out of the box,
    I had a similar problem with a Rapido A class Motorhome, I used a Dremmel cutting tool with a .5mm cutting disc and worked my way around the welted plastic seal to split the unit.
    Once i clear bonded the “jewels” back in place i then fixed the two half’s back together with Sikaflex clear resin bond which is waterproof and is almost a bombproof seal.
    The result was me saving £’sss and the light unit being repaired and restored back to a flawless and perfect state.
    Cheers Andrew
    CCMFF and Mohamed Haider like this.
  8. CCMFF
    CCMFF Rookie
    Nov 2, 2019
    14
    Uxbridge Ontario
    Colin Mason
    [emoji33] you must have a lot of confidence and skill to pull that one off! That said, one would think that a Ferrari specialized mechanic would have a similar solution. I will suggest it to them and see what they say because I’d rather live with it than attempt it my self. Thank you Andrew
  9. John McBride
    John McBride Rookie
    Dec 11, 2019
    29
    John McBride
    This literally happened in my ‘10 Cali over the past weekend, very strange.
    Dseig001 and CCMFF like this.
  10. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Crystal Lake, Illinois
    Alex
    Our 2013 California has a loose one on the driver's side. I'm guessing heat, age and vibration have all played a part in this.
  11. CCMFF
    CCMFF Rookie
    Nov 2, 2019
    14
    Uxbridge Ontario
    Colin Mason
    I looked to see if there was any recall but nothing listed. I don’t trust my self to try to remove the cover lens.
  12. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Alex
    Just drive fast and no one will notice!:)
  13. Bill Phillips
    Bill Phillips Formula Junior
    Nov 4, 2019
    480
    New Orleans
    Bill
    They can be opened and repaired. There are several services listed on eBay that will refurbish them. Expensive, but nowhere near a new one.
