Head removal gt4 | FerrariChat
Head removal gt4
Discussion in '308/328' started by 3px19, Sep 17, 2024.
  1. 3px19
    3px19 Karting
    Aug 29, 2006
    218
    Calvin crouch
    Pulled the engine in June since then have continually lubed head bolts in Kroll. Whack whack whack, judiciously of course, I can't get the heads to loosen. Maybe I'm doing something wrong. Reading the past threads it looks like I need some gizmo/plate to pull up the head. Anyone out there have one I could borrow or rent? I live just south of utica ny. If nearby please come on by and solve this for me. Email address calvincrouch@hotmail. Here's to hope. Thanks cal
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,856
    Atlanta
    John!
    This is common. You need to heat cycle them, get the head very hot with a big propane torch, use a heavy soft-head dead blow hammer from Harbor Freight or wherever. Strong wood 2 x 4 under the correct safe areas, whack whack with big heavy dead blow. May take a few heat cycles. You won't do it with use penetrating oil, heck I don't think that does anything in these situations.
    torch:
    https://www.harborfreight.com/propane-torch-91033.html?utm_source=google&utm_medium=cpc&utm_campaign=12129614380&campaignid=12129614380&utm_content=128613442307&adsetid=128613442307&product=91033&store=202&gad_source=1&gclid=EAIaIQobChMIuaCc-L_KiAMV2ElHAR3c_gnvEAQYASABEgJBM_D_BwE
  3. Ehamilton
    Ehamilton F1 Rookie
    2,645
    Durham, NC; USA
    Eric Hamilton
    Concern about warping the head with this much heat?
  4. Ferraripilot
    May 10, 2006
    17,856
    Atlanta
    John!
    I mean, don't get it absurdly hot, but up around operating temp or just a bit more. So 200-230F or so. Use an infrared temp gun to check while heating so you don't go overboard.
    19633500GT likes this.
  5. Rifledriver
    37,114
    #5 Rifledriver, Sep 17, 2024
    I use 300 F as a limit. Done it many times.
    We know coolant goes to 200-230 with no damage. When coolant is 230 the metal is much hotter.
    We ran a Rodeck at Bonneville at 260-270 water temp many many times.
    Needs to be heated through and through. Hard to imagine getting that job done with a propane torch. Might as well use a cigarette lighter.
    Might as well pee on it as use penetrating oil.
    Ferraripilot and 19633500GT like this.
  6. Ferraripilot
    May 10, 2006
    17,856
    Atlanta
    John!
    A small propane torch, yeah it's not happening, but a big one like I use? No problemo. Use it to superheat blocks to fit interference liners too.
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,586
    San Carlos, CA
    Mitchell Le
    Or make a puller jig.
    DinoParts, Stefan likes this.
