Head Resurfacing Tolerance 1987 Testarossa | FerrariChat
Discussion in 'Boxers/TR/M' started by Muriel, Dec 7, 2022.
  1. Muriel
    Muriel Rookie
    Jul 2, 2012
    14
    What is the max amount removed ?
  2. Steve Magnusson
    26,776
    From page B28 of the TR WSM: "If head resurfacing is necessary, do not machine below the height value indicated in fig. 23."
    Fig. 23 (on page B25): overall thickness (height) of cyl head = 125.20 mm maximum, 125.10 mm minimum
  3. Muriel
    Muriel Rookie
    Jul 2, 2012
    14
  4. Muriel
    Muriel Rookie
    Jul 2, 2012
    14
    Perfect , Thank You !
  5. Steve Magnusson
    26,776
    Please post the thickness (height) of your cyl head(s) before machining. I would hope that F targeted the maximum value when they were made as even from that value there isn't much material available to remove. If F targeted the middle nominal value = that could be trouble...
  6. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,525
    romano schwabel
    if you have to remove more then you would need a thicker and special headgasket. but remember both sides have to been equal
  7. Muriel
    Muriel Rookie
    Jul 2, 2012
    14
    It does appear that the head may have come from original build with the nominal value . We might be looking for a new head ( right side 1-6 ) Will be doing more measurements from various areas and post thickness values next week . Once again, Thank You !
  8. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,068
    Troy, Michigan
    James
    What happened to the head? Haven’t heard too many folks doing this.
  9. Muriel
    Muriel Rookie
    Jul 2, 2012
    14
    Long story short , my own incompetence and failure to think through the entire head removal process methodically In the end, I fabricated an effective head remova
  10. Muriel
    Muriel Rookie
    Jul 2, 2012
    14
    Sorry about that , still making mistakes . Shaved the head through a dumb choice and now in the process of having someone more competent than myself to fix it . Live and learn… still learning . Thank you for all the wise input !
  11. Muriel
    Muriel Rookie
    Jul 2, 2012
    14
    Before machining , the thickness ( height) is 4.905” / 124.6mm . Considering a Clark Copper racing gasket to make up the .020”/ .5mm needed to get to 4.925”/ 125.1mm
    Any thoughts ? Cheers !
  12. Gleggy
    Gleggy Formula 3
    Sep 22, 2004
    1,588
    Land of Oz
    Gleggy
    We can manufacture a set of purpose built 2mm thick gaskets for you to suit the TR. Normal thickness is 1.5mm. This may give enough height to get clearance.
    if this helps let me know.
    Murray
  13. Rifledriver
    37,087
    Prior to reassembly be sure there is not a cam bearing alignment issue.
    turbo-joe likes this.
