360 - Header Help Needed | FerrariChat
360 Header Help Needed
Discussion in '360/430' started by MinoclanF1, Jan 23, 2024.
  1. MinoclanF1
    MinoclanF1 Karting
    108
    Mendham Township, NJ
    Paul H. Ciancimino
    I have an early 1999 360 with no pre-cats or secondary air system. I am putting on an S-line X-pipe. I have been looking at new headers but realized that the ones that I have are probably the same as the Challenge headers.
    Can you give me some advice on whether I should replace my headers (4,000 miles) or not? If I should, what brand do you recommend that doesn't start with an F?
    Many thanks!
  2. one4torque
    one4torque F1 Veteran
    5,734
    Houston
    One4torque
    Dude- 99 headers have no cats to fail.
  3. MinoclanF1
    MinoclanF1 Karting
    108
    Paul H. Ciancimino
    I know. It feels like I don't need to change them. Sound difference?
  4. RedNeck
    RedNeck F1 World Champ
    12,350
    The CSA
    Me
    I also have a '99.The pre-cats are the main reason people change them. I feel that if you have a euro or a '99 it would be a lateral move to replace the headers. The exhaust and cats will have a bigger impact on sound anyway. The S-lines are pretty brutal already.
  5. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,120
    Josh @jtcarprojects
    cavlino and 67bmer like this.
  6. MinoclanF1
    MinoclanF1 Karting
    108
    Paul H. Ciancimino
    What cats do you recommend? I want to avoid the CEL.
  7. RedNeck
    12,350
    The CSA
    Me
    You will typically not get a CEL with any 200 cell cats, you will with test pipes...I personally have the Evoflow cats, among the cheaper brands ($1600), and they are "ok". Sound good and nice welds but wasn't 100% happy with the quality of the stainless steel. Apparently that issue has been fixed since I brought it to their attention, but I'm not even sure the company is around any more. Lots of opinions on this forum...
    cavlino and MinoclanF1 like this.
  8. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,120
    Josh @jtcarprojects
    Using them as well.the driver side rear o2 bung is a little off where I had to reroute the wire a differ way. Not a bigge but if it was clocked more to the outside it would have been perfect
  9. priericky128
    priericky128 Formula Junior
    704
    St. Louis MO
    Rick
    Keep what you have. Non precat headers with no air are the way to go. The sound on mine is perfect (only better with a cs muffler).
    cavlino, MinoclanF1 and RedNeck like this.
  10. RedNeck
    12,350
    The CSA
    Me
    That was also one of my complaints I sent to them. It's not terrible but I hate the way it touches the frame
    clean512 likes this.
  11. anotherred360
    anotherred360 Formula Junior
    Jan 10, 2015
    279
    I also vote to keep the '99 header. I just found a set of new old stock 360 Challenge headers and am going that route. Would've went with '99 headers as they're pretty much the same but I could only find the LH manifold new. Based on youtube it seems the 4-2-1 collector has a higher pitched sound at high rpm. I also think the factory insulation+heat shield setup is superior and/or more durable than the aftermarket options.
  12. MinoclanF1
    MinoclanF1 Karting
    108
    Paul H. Ciancimino
    My S-line X-pipe arrives today!
  13. 67bmer
    67bmer F1 Rookie
    2,986
    MD
