header removal 75 308 gt4 | FerrariChat
Discussion in 'Technical Q&A' started by zman, Jul 5, 2014.
  1. zman
    zman Formula Junior
    Jan 14, 2006
    356
    Toronto, Ontario
    I'm having a hard time removing the rear header off the engine. I have the muffler out and the header is dropped but can't seem to get it out. What do I do?
  2. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,032
    Summerfield, NC
    Tom Jones
    Drop the park brake linkage. Sometimes you may need to remove the motor mount bolts and torque bar to the rear cam cover and slide the engine assembly forward.
  3. BigTex
    79,368
    Houston, Texas
    Bubba
    The easiest way (based upon my time under my GTB) is to bite the bullet and remove the RH tank.
    Doing this and also unbolting your motor mounts, and carefully raising the engine, will give you enough room to roll a complete header out of the RH wheel well.
    My job was a little easier because my header had exploded to pieces...lighting the car on fire
    But, I still had to fit the new complete unit in, and that's how I did it...
    Your suspension, and brake system can stay together, which is what is "in the way"..
  4. BigTex
    79,368
    Houston, Texas
    Bubba
    Right, jacking the motor, after doing this, creates clearance.
    Brakes on mine stayed in place, just move the engine.
  5. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    RH tank needs to come out if you are pulling out the front header not rear the header.
