Headers cracking? | FerrariChat
Headers cracking?
Discussion in '348/355' started by nsx2F355, Jun 6, 2013.
  1. nsx2F355
    nsx2F355 Formula Junior
    Mar 12, 2013
    708
    SLC
    Tony
    Had my 95 355 for a year now and 3.5 years from the last major. How would one now when the factory headers are beginning to crack or leak? I familiar that they are weak spot in the 355 but I don't know how to tell when they are going out. Any help would be greatly appreciated. Taking a long road trip from LA to Monterey in mid Aug. Then back to SLC, UT. Dont want any major issues along the way. Italian Stampede!! 100 Italian only cars up the coast for Monterey Weekend. Join us. Thank you
  2. stevew3765
    stevew3765 Formula Junior
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    SCREW IT! I'M MOVING TO CALIFORNIA!
  3. 355rockit
    355rockit Formula Junior
    Dec 1, 2010
    893
    San Marcos, CA
    Vas
    Some folks put a spot of oil on top of the oil filter to catch any header insulation material in order to see there is a leak. The engine will lean out if there is a leak, but if this may be due to other factors such as O2 sensor, MAF, leaking donut seals between header and cats, etc. Only other way to really verify is to scope and smoke test the headers.
  4. kj2001m5
    kj2001m5 Karting
    Aug 7, 2009
    121
    I know this is a hard question to answer, but am looking for a really rough estimate. How long will factory headers last? Is there a certain number of miles these can typically go?
  5. BigTex
    79,406
    Houston, Texas
    Bubba
    Did they put new units on during your service, or still on your first set?
    It totally depends on how you use the car, really.
    It's related to the heat of course.
    Answer above is correct, test them....
    They basically should be considered a "wear item" like tires.
    As mentioned you look for the insulation to start blowing out as a powder, from the wrapping....
  6. nsx2F355
    Mar 12, 2013
    708
    SLC
    Tony
    I will give that a go. I do not think they have been replaced yet. Car has 33k on it now. Runs fantastic but get the occaisional 1-4 check engine then turns off mins later.
  7. jgriff
    jgriff Formula 3
    Jun 16, 2008
    1,125
    Houston, TX
    Mine has 31k miles on the original headers.
    Sent from my iPad using Tapatalk HD
  8. 355rockit
    Dec 1, 2010
    893
    San Marcos, CA
    Vas
    I would check and clean the contacts for the sensor connectors (MAFs, O2 Sensors, etc). It will help to eliminate some gremlins. You may want to pull codes to see what the car thinks is a problem. Long term solution to electrical gremlins is Helms Gold Connector Kit. It is on my list of things to do. Cleaning the contacts did resolve some of the gremlins.
    I had an intermittent 5-8 CEL that seemed previous owners of my car saw as well. Turned out that one of the female pins in the ECU MAF connector was off center and not making a good contact with the male MAF connector. After pushing the metal contacts into place, I haven't had the pesky intermittent 5-8 light since.
  9. kj2001m5
    kj2001m5 Karting
    Aug 7, 2009
    121
    By the way, sorry for hijacking the thread. I figured it was question directly related to the topic.
    Mine were replaced about 2500 miles ago (at 44,000) during the last major
  10. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    When I had my engine out for service, I dropped in Tubi headers and forget about it. Even got back 900 for the old headers that were still good. So my total for tubis came to 4500. I figured, why use a broom handle when for a little more I could buy a Louisville slugger.
  11. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Tubi only provides a one year warranty. No way I'm paying that kind of money when the company won't even stand behind their product for more than one year
    Dave helms told me in a personal conversation that he would only use the new OEM headers period at this point if necessary.
    Save your nickels up :)
  12. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    Strange because Dave said only a couple of years ago that tubi was the only alternative. Maybe tubi offers only a 1 year warranty but they will last as long as the car and that's what really matters.
  13. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    This was a conversation I had a couple months ago. I think they changed their warranty policy which changed his mind.
  14. tbakowsky
    Sep 18, 2002
    20,035
    The Cold North
    Tom
    Take it to your tech and have them use their smoke machine to test the manifolds for leaks. It will be very obvious. If you have a good ear..you should be able to hear it as well.
  15. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    I've wondered about the headers as well since mine are still original with 34k miles on them.
    I'd like to know more about this drive in August?
  16. phrogs
    phrogs F1 Veteran
    7,357
    Kzoo Michigan
    A bore scope will work as well. But would require some disassembly. But just the cats.
  17. Evan.Fiorentino
    Evan.Fiorentino F1 Rookie
    Aug 23, 2005
    2,854
    South East Florida
    Evan
    It is very tough to tell when a failure is imminent because of the factory heat shields that block your view. The best advise I can give is to replace them sooner rather than later to prevent failure. Going to PM you more info.
  18. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I had the same chat with Dave. He said the OEM headers are far better than any aftermarket in respect to design flow. As many know, Dave feels the issue with headers is related to excess fuel being burned...
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I was told that you can hear when the headers fail, with no confusion.
  20. ezmaass
    ezmaass Karting
    Apr 26, 2013
    186
    CT
    Eric
    It's good to know there are many cars with 30k and 40k miles on them with OEM headers. Out of curiosity, it would be interesting to have people respond with their current mileage if they're still running on original headers. Likewise, it would be interesting for people to post at what mileage their headers failed, if applicable. It would be interesting to plot the data from a statistical perspective to see if there are any patterns. You'd need quite a bit sample to get anything meaningful out of it, so it may not be anything more than anecdotal, and driving still and other factors tend to contribute to the failure (or lack thereof)... but nonetheless interesting to see.
  21. fatbillybob
    Aug 10, 2002
    29,255
    socal
    do you generally have to seal the tailpipes and run the smoke up one of them or if you run smoke up the tailpipe and lots bleeds out the other tailpipes the smoke still finds its way to the manifolds?
  22. M. Brandon Motorcars
    Sponsor
    Sep 4, 2007
    1,846
    Houston, TX
    Michael Foertsch
    My 97 355 Spider at 19K miles still has the OEM headers. (In fact, it's completely OEM, no mods)
    Just had an engine-out done. I asked my tech whether to replace the headers, and he said if they don't have issues, just leave them alone.
  23. cuneo
    cuneo Formula 3
    2,484
    My OEM original headers failed at about 26-27K miles. Fabspeed since then (and a top end rebuild with lower refresh) and now have 44,700 miles and it runs perfectly.
  24. Evan.Fiorentino
    Aug 23, 2005
    2,854
    South East Florida
    Evan
    In some cases, yes. When a crack has already developed you should be able to hear it. However, while the metal is weakening and beginning to fail but has not fully created a crack that would be audible it could be tough. The point is to try to address it before it becomes an issue potentially leading to catastrophic engine failure. Someone had mentioned smoke, which could also work very well.
  25. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    I have always wondered how the smoke test is done with the headers still fitted to the car.
    Anybody prepared to enlighten me?
