Headers - "Titanium Wrap" or Header Blankets | FerrariChat
Discussion in '360/430' started by whatheheck, Feb 23, 2019.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Here you go for sharing.
    I installed Agency Power Headers & Kline Innovation exhaust on my F430 Spider a year ago now.
    Header Blankets were expensive so I decided to go with "Titanium Wrap".
    A year later I discovered the titanium wrap are starting to deteriorate already. Crap, that was a waste of time so time to upgrade to header blankets.
    Thanks to member Eric55. He discovered another seller of header blankets for our F430 for a much reasonable price. And according to him, its been a year now since he installed his and its still going strong so I decided to install one.
    Looks great, easy install, works great.
    Below are some photos. Attached is a complete DIY write up to make it an easier install for others.
    Hope this helps some of you.
    Dan
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Flea7, gperson, cpep and 3 others like this.
  3. f355spider
    f355spider F1 World Champ
    18,033
    Dan, it looks like your header wrap was getting baked and "crispy", causing it to "crumble", would that be an accurate description? What brand of wrap did you use?
    Blankets look sharp, good luck with them! :)
    whatheheck likes this.
  4. F355Bob
    F355Bob Formula 3
    Image Unavailable, Please Login I had Capristo and Fabspeed blankets. They worked well but the white Capristo got dirty real fast and the Fabspeed were ok but ended up going with Inconel which work really well. I can put may hand and inch away after a hard run. Works better than blankets and used by many racers and on turbos.
    Janjie, ShineKen, KC360 FL and 3 others like this.
  5. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Hi Dave,
    Yes, that is a better description. It became crispy and once you touch it it starts to crumble.
    And very good point too that its possible its the brand that I used.
    I used this one & I cant recommend it to anyone:
    https://smile.amazon.com/dp/B011B99B0I/ref=cm_sw_em_r_mt_dp_U_EERCCb9FS5CSM
    Dan
    cpep likes this.
  6. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks for sharing great info.
    Can you share with us who made your Inconel heat shield and how's the price compared to Fabspeed?
    Dan
  7. cpep
    cpep Formula Junior
    437
    new york
    CHARLIE
    I tried that one and ended up taking it back off because it wouldn't wrap correctly (kept bunching up and folding) . I ended up going with DEI and it wrapped a lot better. My problem is I have a black car and you can see the fibers all over the back so I know it must be coming apart in some way. I do like that inconel wrap.
  8. F355Bob
    F355Bob Formula 3
    I had them made but TurboSource in Minnesota. They were around $1600 for both headers. Worked better than blankets.
    Radiant heat is minimal, looks better, better fit, easier to keep clean. Look at a race car and you will see inconel heat shields everywhere for a reason.
    d16dcoe45, f355spider and whatheheck like this.
  9. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Hi Charlie,
    Thanks for sharing info.
    That is also one of the issues I had with the Titanium wrap. The fibers starts coming off and its now all over the engine bay..........made my engine bay dirty.
    Hate it.
    I had to clean my engine bay again using the scrubbing bubbles method and now my engine bay is super clean again.
    No more titanium wrap for me.
    Dan
    cpep likes this.
  10. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Got it.
    We'll see how long this header blankets last and if they dont last very long I will switch to Inconel Heat Shields.
    Thanks again for the info.
    Dan
  11. Metastable
    Metastable Formula Junior
    So the Inconel...... I assume you need to remove the headers to wrap it?
  12. BlacktopRacing
    BlacktopRacing Formula Junior
    996
    Pittsburgh
    Dale
    Those NHP header blankets look a lot like the Fabspeed ones. What are the differences? I see the holes for headers that have O2 sensors in the same position as the OEM MKII manifolds, but am wondering if you can get them without? Do they install pretty much the same as the Fabspeed ones with similar hardware? I ask these questions because I am interested in getting a set. Thanks.
  13. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    How much did you pay WhatTheHeck header blankets ?
  14. F355Bob
    F355Bob Formula 3
    Yes
  15. Metastable
    Conundrum..... I wrapped mine with the DEI wrap..... then sprayed them with the DEI black silicone spray. I think your solution is better though.
    However...... I have not installed them yet. Where do you buy the stuff? How hard is it to wrap it?
  16. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,119
    Fort Washington, PA
    John S
    Phil from Fabspeed here.
    Blankets are the way to go.
    If you are going to coat I would suggest wrapping as well. Coating is great but it gets so hot the coating will end up cracking. Once the coating cracks it becomes vulnerable and heat really starts to escape.
  17. zboost300
    zboost300 Karting
    Jan 27, 2019
    140
    How is your wrap holding up? I plan on doing DEI with the silicone spray
  18. Metastable
    So far so good, but I haven’t done that many miles..... about 1000 miles.
    I did cook the headers between each coat. Note, my first coat was the black spray, but then I found out they have a silver spray, so I used that for the next 3 coats. You should do at least 3 coats, but I did 4. The first coat heat cycle is very smoky (because of the wrap, not the spray). However the good thing is that when I drove the car after doing all the heat cycles on the wrap, it smoked very little for 5 minutes, then it was done.
  19. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,119
    Fort Washington, PA
    John S
    Hey RANDY,
    Header blankets are another way you can insulate the headers. This video below explains it in depth.
    Corvette C8 (2020+) | Fabspeed Sport Cats and Cat Bypass | Product Comparison and Rundown
    Janjie likes this.
  20. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Just want to provide a quick update on this to share info and my experience with others.
    I installed Capristo Header Blankets on my F430 (now sold).
    Capristo makes excellent header blankets and it drastically reduced engine bay heat emitted by the aftermarket headers.
    1,000% happy with it and worth every penny.
    Even my mechanic said Those are very well made and it really made a big difference in containing heat.
  21. zboost300
    zboost300 Karting
    Jan 27, 2019
    140
    Very interested in those cat blankets... I had planned to wrap if I have left over wrap.
  22. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,922
    Isle of man- uk
    The manifold blankets should last for years provided you do not get any manifold leaks, leaks will blow holes in them. We used to have lagging on steam pipes for years but a leak would make short work of the insulation, some used to be asbestos in the old days, nice stuff to work with !!!!!
  23. Metastable
    Well ... just an update on the DEI titanium wrap with the high temp silicone coating. I have done around 2000 miles (not kilometres) and it is looking like new still. The darkness you see in the picture is from a shadow.
    Things will remain the same until next summer, because the car is scheduled to go into storage next week.
    Ogonju and f355spider like this.
  24. zboost300
    zboost300 Karting
    Jan 27, 2019
    140
    I am running dei titanium beat wrap as well. Sprayed it with their black silicone spray.
    Factory cats as well do they are getting more heat I would assume. So far so good.
  25. RichardCH
    RichardCH F1 Rookie
    4,661
    I think the NHP Maxspeed blankets are indeed exactly the same as the "other" US suppliers just half the price at $995
