Headers, Y-pipe, Test Pipes, Exhaust need retuning/re-mapping on 2.7 for 91 pump? | FerrariChat
Discussion in '348/355' started by ShineKen, Jun 4, 2013.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,032
    Southern California
    Nostradamus
    I had visited RSD Japan late last year to check out some of their setups and their track 355 was fitted with a Saclam full exhaust system (headers, de-catted, exhaust). They said this system required no extra tuning and worked perfectly well with the 2.7 Motronic. They also mentioned with an added air intake system, it would be borderline lean. I don't plan on running an intake system anytime soon. Japan uses 100 octane , which is close to our 93. My question is if after-market headers , full decat, and exhaust is safe for 91 pump gas with the 2.7 as I've read it runs a little rich from the get go.
  2. ShineKen
    20,032
    Southern California
    Nostradamus
    #2 ShineKen, Jun 4, 2013
  3. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,741
    Nice looking headers, they seem to (finally) be of the correct length.
    They could get another 3-5 HP from the system with a properly sized expansion chamber after the collector.
    As to mods like this, after you do them, you really shod have the car on a dyno and have the 2.7 system remapped to avoid leanness.
  4. FlyingAces
    FlyingAces Formula Junior
    Jun 2, 2011
    849
    LA 2 Vegas
    Joejoe
    #4 FlyingAces, Jun 5, 2013
    sweet looking thing. 11K no thanks :)
  5. ShineKen
    20,032
    Southern California
    Nostradamus
    This system retail for 10,000,000 yen. Current USD rate is 1 to 120 as of today. That puts this FULL ( headers + muffler) exhaust system at $8,300. Quality headers ($3000) + y pipe ($700) + straight pipes ($500) + muffler ($3500) will put you close to that number.
    Here's the setup in action doing about 1:03 secs at Tsukuba on an untuned ecu with a stock intake system. 458 does this track in 1:02-1:03 in stock form.
    http://youtu.be/xAqiMYXw6Ko
  6. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    Great video! The driver is keeping very busy there!
  7. ShineKen
    20,032
    Southern California
    Nostradamus
    2000 lb front challenge spring rate. This is the roughest car Ive ever seen performing on this track.
  8. Evan.Fiorentino
    Evan.Fiorentino F1 Rookie
    Aug 23, 2005
    2,854
    South East Florida
    Evan
    As in most cases, you shouldn't *need* to retune the car to perform with this exhaust. However, generally speaking, a proper tuning session will ensure that the AFRs are at a safe level (not too lean) and you will fully optimize the exhaust potential. I put a full exhaust on a 348 (no cats) and the AFRs stayed perfectly fine :)
