430 - Headers | FerrariChat
430 Headers
Discussion in '360/430' started by Klas, Feb 19, 2023.
  1. Klas
    Klas Formula Junior
    Mar 17, 2014
    364
    Gothenburg, Sweden
    Klas Nilsson
    Hi
    Did Ferrari improve the weak headers at some point? I red that from model year 2008 they were reinforced but is that true?
  2. GogglesPisano
    GogglesPisano F1 Rookie
    3,208
    East Bay, California
    Joe
    Yes, they made an improved version that still failed but at a slower rate.
    cavlino and midengine like this.
  3. 1FG1V3N
    1FG1V3N Rookie
    Jul 28, 2022
    13
    Amsterdam, NL
    JM
    My model year 2008 had the "new and improved headers" and they failed.
    Bought new Challenge headers from factory. Which are very affordable compared to aftermarket headers.
    These headers do not have pre-cats, so there is no risk for major (engine) problems if they fail in the future.
    Also removed lower exhaust brackets to avoid stress on the headers.
    The car is running fine and no CEL whatsoever.
    There is more Fchat folks that have applied the same solution and can confirm this.
    cavlino likes this.
  4. nchhotu
    nchhotu Formula Junior
    316
    Roseville, Ca.
    Nick
    I did the same. Really like the sound. Make sure you reset your ECU by turning off the battery for a day.
    cavlino likes this.
  5. Martyb777
    Martyb777 Rookie
    Mar 13, 2022
    36
    Marty Bauer
    Best place to source the challenge headers?
  6. nchhotu
    316
    Roseville, Ca.
    Nick
    Eurospares. I received mine in a few weeks as they were on back order. If they have them in stock it's 3-4 days from order.
    cavlino likes this.
  7. nchhotu
    316
    Roseville, Ca.
    Nick
  8. nchhotu
    316
    Roseville, Ca.
    Nick
  9. CoreyNJ
    CoreyNJ Formula 3
    2,460
    New Jersey Shore
    Here are the part numbers..
    Challenge Headers - 232826 LH. 232825 RH
    Don't forget he needs to order all the plugs and adapters also, don't bother reusing the old stuff.
    2- 150595 NUT
    2- 144240 UNION
    2- 236195 PLUG
    and you should buy some new studs and an exhaust gasket/donuts
    16- 211641 STUD
    16- 210971 NUT
    2- 154985 GASKET
    2- 211404 GASKET
  10. nchhotu
    316
    Roseville, Ca.
    Nick
    Yes! Very good point!
  11. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    I've noticed the prices changes on these headers. A while back they were 640 and today they are over $2k. There are times when they list them at around 1k each.
  12. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    Thanks for this info. Would M8 copper nuts be better for the studs? I also bought replacement titanium bolts from headers to cats w info from AV. https://aldousvoice.com/2014/03/25/ferrari-f430-exhaust-manifold-change/
