Headlamp twist knob ball and spring replacements? | FerrariChat
Discussion in '308/328' started by bergxu, Aug 24, 2010.
  1. bergxu
    bergxu Formula 3
    Aug 16, 2005
    1,307
    OnTheSerpentMound
    Aaron
    Hey all,
    Has anyone had any luck with sourcing a replacement ball and spring for their headlamp twist knob? Seems as though the cause of the loose switch on this '82 is that the ball and spring have gone missing. Thanks in advance for any help!
    Cheers,
    Aaron
  2. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Contact Verell at Unobtainium Supply. You'll find him on here. He's the guru of how-to as far as the switch stalks in the 3x8s goes. He redid the ones in the '78 308 I had and did a brilliant job at that. He can probably help you out.
  3. Raricar
    Raricar Karting
    Jun 17, 2010
    246
    Greenwood Village CO
    Bill M
    Just been there... The spring is .40 (10mm) long with a coil diameter of .157 ( 4 mm) and uses .030 (.76 mm) wire with 6 coils. The Ball is .185 dia (4.69mm). I think any thing close to these dim's should work. I found a good local hardware store with a close match. Or McMaster-Carr has a good match, you may have to cut the spring to length. Pain in the butt switch.
  4. Raricar
    Raricar Karting
    Jun 17, 2010
    246
    Bill M
  5. bergxu
    bergxu Formula 3
    Aug 16, 2005
    1,307
    OnTheSerpentMound
    Aaron
    Steve,
    Have an email in to Verell.
    Bill,
    Appreciate the measurements! Will pop by one of the local hardware stores and see what they've got.
    Thanks!
    Aaron
  6. thecarreaper
    thecarreaper F1 World Champ
    18,057
    Savannah
    thank you for that post, seriously ! :)
  7. shashi27
    shashi27 Formula Junior
    Jan 7, 2006
    988
    Long Valley, NJ
    Shashi
    +1 Tired of flashing people when I reach for the turn signals!
  8. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #8 Verell, Sep 4, 2010
    Aaron,
    I'm sending your ball & spring out Monday. No charge for them or for for 1st class mail, or you can send me $4.90 PayPal for priority mail & get 2nd or 3rd day delivery.
    You'll have to cut the spring to length, just fit it into the hole & cut it with about 1/2 turn extending out of the hole. Then put some dielectric grease on the spring & install it with the cut end inwards. The dialectric grease itn's absolutely necessary, it's to keep the spring from shooting out if/when pressure on it is released.
  9. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Shashi,
    See preceding post. Send $4.90 PayPal to [email protected], or email your address to the same for 1st class mail.
    Verell
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    I just had to re-order these springs. The little precision springs & SS balls cost quite a bit more than I was remembering.
    Starting now, please send $8.90 PayPal to: [email protected] for a ball & spring pair. They'll ship USPS Priority Mail, so you should receive them in less than a week, usually about 3 days.
    The dialectric grease is not absolutely necessary, it's to keep the spring from shooting out in case pressure on it is suddenly released.
  11. shashi27
    Jan 7, 2006
    988
    Long Valley, NJ
    Shashi
    Thanks, Verell. The spring an ball were missing from mine and now the switch clicks nice and tight. No more inadvertent flashing. Awesome.
  12. BDOLIN
    BDOLIN Rookie
    Aug 10, 2010
    31
    NJ, MO
    Brian Dolin
    The ball is a 3/16" ball bearing and the spring is a #1- 5/32" X 1" long. These are available at Ace Hardware. Buy 2 of each because you will loose one when doing the job.
    The spring will have to be cut to about 1/2-5/8" with a Dremel tool or grinding wheel. Grind the end flat after you cut it.
    DO NOT test fit the ball into the pod because it will fall in and stay there forever. Place the spring inside the hole for it, balance the ball on the spring and push it down while sliding the knob over the switch. After the first set shoots off into Never-Never Land, you will be glad you bought two.
