Headlight lifting motors-manual knob | FerrariChat
Discussion in '308/328' started by Michael DB, Apr 7, 2024.
  1. Michael DB
    Michael DB Karting
    Dec 22, 2023
    236
    Michael D Beswick
    The knob to manually raise the headlights rotates, but does not raise (either) headlight. Is this common/easy fix, or a complete strip down of the motor assembly?
  2. sack
    sack Rookie
    Nov 6, 2023
    26
    Germany
    Marc
    Does it move electrically? The knob is clipped onto the end of the motor axis which has a hexagon shape. You can detach the knob using a little bit of force. Due to the transmission you have to rotate it many times to see a movement on the other side.
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
    You have to turn the knob a lot before it will barely move
    kiwiokie likes this.
  4. Michael DB
    Michael DB Karting
    Dec 22, 2023
    236
    Michael D Beswick
    Thanks both. I turned it a lot! It doesn't feel as though it is turning what I presume is quite a "strong" motor, more just spinning. If it's just a plastic knob on a hex on the shaft, I wonder if the hex has "worn".
    I was changing the headlight bulbs and more by luck than judgement put up the lights and then disconnected the battery earth.
  5. Michael DB
    Michael DB Karting
    Dec 22, 2023
    236
    Michael D Beswick
    When working does the knob rotate as the headlight buckets comes up/down?
  6. Dockboy
    Dockboy Formula Junior
    608
    Maryland
    Yes
    Michael DB likes this.
  7. Michael DB
    Michael DB Karting
    Dec 22, 2023
    236
    Michael D Beswick
    To conclude:
    I didn't fully understand "a lot"! With Grandson at the controls I watched the knob spin "a lot" as the headlights lifted. I hope I never have to do it in earnest in the dark; I reckon it would take 5 minutes to lift each light!
  8. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    748
    Omaha, NE area, US
    Steve
    Just did the manual HL lift to facilitate removal of the lower fascia. Takes maybe 10 seconds of spinning the knob. I was doing it with the grilles behind the HL removed, so easy access, btw.
