Headlight Motor Diode Replacement | FerrariChat
Discussion in '308/328' started by sm1, Mar 27, 2017.
  1. sm1
    sm1 Rookie
    Oct 10, 2013
    3
    #1 sm1, Mar 27, 2017
    I believe I've traced my headlight winking down to a bad diode on the driver-side motor (open circuit in both directions).
    However, under the rubber casing, the whole motor and electricals are covered in some thick, rhino-liner like material (pictured). Anybody have any tips on out to cut/melt/dissolve through this stuff? Would hate to replace the whole motor for a component that's literally less than a dollar at an electronics store.
    Thanks for any suggestions!
    Scott
  2. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    #2 Matto, Mar 27, 2017
  3. sm1
    sm1 Rookie
    Oct 10, 2013
    3
    Thanks, Matto! I'd referred to that post for diagnostics, but I have no idea where they got such a clean motor! All the used replacement motors I've found ($300-400) across a number of sources have that gnarly coating on them. Will try to shave away at it with an exacto if nothing else comes up.
