Headlight motor splined nut | FerrariChat
Discussion in '348/355' started by MrJames, Sep 11, 2020.
  1. MrJames
    MrJames Karting
    Apr 12, 2020
    62
    South Florida
    James Webb
    Hey guys, I'm working on a left headlight that doesn't go up. I found the procedure here for removing it and taking it apart, which has mostly been super great. (Some horrible black liquid came out when I removed the gearbox cover, for instance.) But there's nothing in the writeup about this particular splined nut. It doesn't seem to want to come off. I've already stripped the non-splined part of it a bit with vice grips, and I'm afraid I'll be doing serious damage (or seriously embarrassing myself) if I try to overpower this thing. Is there a trick I'm missing? Should I use fire? Does it somehow not actually have to come off? I know I can clean up the contacts without removing the gear, but I wanted to make sure all the grit and grossness was out of there before I added new grease. Thanks!
