Headlight pod moving a little slow | FerrariChat
Discussion in '348/355' started by lotusk, Jul 17, 2015.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Yup
    Have tried two right hand side headlamp pod motors...a new OEM and the original that has been renovated with new diodes.
    Both work in as much as the pod goes up and the pod goes down but......
    the pod comes up at a slightly slower speed than the left one...looks pretty bad when operating...
    Tried swapping relays but made no difference.
    What can i do to get the pods opening at the same speed?
    They used to be perfect until the right hand motor refused to close the pod.
    I had this renovated and in the meantime fitted a new one that i had as a spare.
    Both motors open the pod at the slower speed.
    Any ideas???
  2. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    If they are both moving slow, then maybe full power is not reaching the motors for some reason. Check the grounds for that line.
  3. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Only the right hand is rising slow
    Left hand is normal
  4. m.stojanovic
    m.stojanovic F1 Rookie
    3,288
    Serbia - Niš
    Miroljub Stojanovic
    It is possible that you have a bad connection in the wiring to the RH motor introducing resistance. Check the inline connector of the black wire and its connection to the ground and make sure that the grounding point has good ground. Also check the connections of Fuse #4 and connections of the red wire to the fuse block and at the inline connector at the motor.
