headlights go up/down, no parking lights, signal out... | FerrariChat
Discussion in '308/328' started by Veleno, Dec 22, 2010.
  1. Veleno
    Veleno Rookie
    Jan 10, 2010
    25
    So my headlights go up then down, or one side goes up then down. It doesn't stay up for very long, maybe 2-3 seconds. I've read a little about cleaning the switch, changing relays, but is there anything else I should do or check? Help me drive the car at night!
  2. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Please fill out your profile with year model us/euro etc info as the 3x8s may look alike but are slightly different inside.
    First thing to do when the eyeballs don't snap up together is reverse the left and right headlight lift relays. If the symptoms reverse sides, replace all 3 relays. (there is a master relay as well). If symptoms don't change sides, your problem is in the lift pod. The contacts get dirty and diodes go bad. There is a very small possibility that the connector near the pod has a bad connector. But hope for a relay fix which is the cheapest and fastest and most likely.
    Bosch Lift relays numbers end in 101
    Relay numbers - http://www.ferrarichat.com/forum/showthread.php?t=304815
    __________________________
    http://www.FerrariDiagrams.com
