headliner cleaning | FerrariChat
headliner cleaning
Discussion in 'Technical Q&A' started by bill brooks, Sep 6, 2007.
  1. bill brooks
    bill brooks F1 Veteran
    6,090
    waynesburg,pa
    bill brooks
    has anyone ever cleaned the fabric headliner and fabric shelf behind the seats on a 328?
    mine has some brownish stains, similar to coffee stains in various places.
    i didn't want to do the stupid thing without conferring with the experts first....thanks.
  2. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,088
    Wellington, FL
    Duane
    I would approach this carefully. My top had some stains and I could not get them out, in fact I made them worse. It took a great deal of effort and expense to get enough material to recover the top, of course I have the black/white stripe material and it's unobtanium. If you have the brown stripe material it is readily available.
  3. bill brooks
    6,090
    waynesburg,pa
    bill brooks
    naturally, it's the black/white unobtanium.(did penske/donohue market car fabrics also?)
  4. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,088
    Wellington, FL
    Duane
    I would call Algar and see if they have any material and also if they recommend a cleaning procedure.
    I used some carpet cleaner and like I said it made the stains larger, just kind of spread them out really.
  5. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    #5 Iain, Sep 7, 2007
    That fabric they put round the rear window/parcel shelf etc on the 308/328 GTSs was the stupidest idea ever! When I bought my car I had those areas (and the inside of the roof panel) re-trimmed in crema leather to match the rest of the car.
    Because its light coloured leather you can now see just how much dirt & crap gets in there just from normal use - which is why cars with original fabric can look so decidely grubby inside
    Being leather its also now dead easy to keep clean. :D It also looks a million times better (even when its not 100% clean!) & it didn't cost a fortune to do. It also makes the inside of the car might lighter & brighter when the roof is on (won't apply with Black leather of course!).
    Suggest you shop around & see if you can find someone to do your car for you.
    As it happens I took a picture of the retrimmed bits a while ago - its a bit dark but you'll get the idea - see attached
  6. dave80gtsi
    dave80gtsi Formula 3
    1,948
    Ohio
    Dave Meredith
    #6 dave80gtsi, Sep 7, 2007
    You'd be amazed at the amount of grime that the cloth rear deck / window surround will collect.
    Here's the OEM cloth bits, removed. Note the white stripes at the very edges of the big "L" pieces, at the center of the picture. That's the original color, which was hidden behind that center clip!
    And the second picture is of the end result, completely redone in a creme colored leather.
    Cheers - DM
  7. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    I just removed the cloth and painted the pieces wrinkle black. Nobody notices. If you are not going to go original, why bother with covering it with something else (though, I must say, the creme leather looks nice).
  8. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Umm....cos it looks nice :D !!!
    (not sure about the crema leather with the black seats though!)
  9. bill brooks
    6,090
    waynesburg,pa
    bill brooks
    well... thanks folks nice pix of leather. but has anyone actually tried to clean these surfaces?
    algar and continental both were unsure of procedures. surely someone in the flock has cleaned
    these areas successfully.
  10. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Bill I think that's the point - nobody really has, its been asked about a number of times. I would think your best chance of really cleaning the stuff might even be to remove it from the car but whatever you do I think its always going to look not quite clean. Leather is the way to go IMO.
    I.
  11. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    My 308's fabric is worn through in many places so cleaning is a waste for me.
    How hard would it be to get these pieces out of the car to paint or recover?
    Is there a sequence/procedure I can read about?
    thanks.
    P.S. - I'm missing the two bracket plates that go on the ceiling to receive the roof's rear latches. Does anybody have a picture of theirs out of the car I can see? I may need to make up something close if I can't find originals.
    Again, thanks.
  12. Eric308gtsiqv
    Eric308gtsiqv Formula 3
    Nov 26, 2001
    1,956
    Orange Park, Florida
    Eric Eiland
    I cleaned mine years ago using OxiClean, with excellent results.
    Used OxiClean "powder" and mixed according to the instructions with very warm water in a spray bottle. Let it set for roughly 30 minutes, followed by a wipe down using a damp white terry cloth rag continually soaking in a small bucket of warm water, ring excess, wipe, repeat until all surfaces were wiped down.
    Followed by a complete wipe down using several dry white terry cloth towels. You will be amazed at the amount of dirt that the towels will pick up.
    Repeat steps above until clean to your satisfaction.
    It is always best to "test" clean a small area in an inconspicuous place first to make sure there wont be any problems with the fabric in your 308 due to age differences / exposures / etc. I'd also recommend not rubbing too hard with the rags / towels -- in other words, several light applications are better than one heavy soaking.
    The OxiClean came with rather comprehensive instructions for recommended use in the container.
    You might want to give it a try.
  13. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,699
    NJ
    Peter
    There is a carpet clean called Folex available at, of all places, Home Depot. It's amazing what this stuff will remove -- auto detailing sites praise this product and it doesn't have any chemical smell like most carpet cleaners. Definitely test in a small spot to make sure it's safe for your fabric, but it would be surprising if this stuff didn't work.
    moysiuan likes this.
  14. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    I have been told by others here that Oxiclean and a fabric cleaner by Zymol both work well.
  15. 38 Off
    38 Off Karting
    Nov 4, 2003
    248
    Pace, FL
    Phil Crain
    +1
  16. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    It looks and smells nice and can be easily cleaned.
    If you are not going to go original, why bother with covering it with something else (though, I must say, the creme leather looks nice).[/QUOTE]
  17. Stenley
    Stenley Karting
    Oct 20, 2020
    54
    Los Angeles
    Scott Tenley
    Hi everyone,
    New 328 owner here and I'm loving both the car and this community of experts. The site has already had a dramatic impact on my enjoyment - I found that great thread on fixing the VW whistle from the exhaust and employed the advice to great results.
    As for this thread, i notice that it hasn't been updated in a few years. Is there any new advice on how to clean those nasty spots on the fabric shelf? i have a few and wondering if Oxyclean remains the state of the art solution. Any advice is greatly appreciated.
  18. afterburner
    afterburner F1 Rookie
    3,502
    Switzerland
    Urs STEMMLER
    Since it's a wool fabric, you can use a hand-wash wool detergent and plenty of cold water from the shower head with a brush - on the removed panels. Worked on my Mondial headiner; amazing what came out...
