Headrest question | FerrariChat
Headrest question
Discussion in '308/328' started by 11506apollo, Feb 15, 2012.
  1. 11506apollo
    11506apollo F1 Rookie
    2,698
    Tx Co Ca
    Hi guys, I need to remove one of the headrest on my 82 GTSi so I can take it to a shop for a leather match check. I can pull it up a notch, but then it won't come up further. Seems like it is locked in there. Does it come all the way out if I pull hard enough or are the two vertical rods enbeded in there? Thanks.
  2. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    you have to remove the seat back covering. there is something in there holding the rods. do a search, there are some good threads on this procedure.
  3. 11506apollo
    2,698
    Tx Co Ca
  4. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Quite frankly, it will be easier for you to take the entire seat to the shop rather than go through the drill of removing the headrest.
  5. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    I did mine a couple weeks ago. Pain in the ..... . Bring the seat. There is a thread I found showing a picture of it. If you do a search you'll find it.
  6. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    two clips in the seat, you have to remove the leather and cut the foam with a razor.
    pull clips then the head rest lifts up.
    Rocco
  7. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
  8. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    I went through that whole procedure, and found no pins in my seat back, and it didnt look like it had ever been opened up. the headrest was stuck in there like a mo-fo.
    It made me wonder why there are notches in the hest rest posts? are you really supposed to take the pins out, adjust the headrest, then reset the pins?
  9. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    I tried very hard to pull on mine to get them out and coudn't do it. After removing the pins they came out right away. I was thinking about making a tool to override the job of taking the seat appart. It would be a tube cut in half on it's lenght to slide along the headrest post, push it down to cover the notches and then pull the headrest. I think it would work.
  10. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,804
    Cerritos, CA.
    This is what I do, I remove my targa top off then I stand on the seat and I wiggle the head rest while pulling it up.
  11. klatu
    klatu Formula Junior
    Apr 13, 2009
    277
    San Diego
    Rob Mckinney
    I might give you a dollar for a photo of you doing that.
    Klatu
  12. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    LOL. I did that too - nearly gave myself a hernia. Never did find any pins.
  13. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    628
    Massachusetts
    Joe
    #13 jmaienza, Feb 17, 2012
    78 308 GTS USA model. There is a clip, the back doesn't have to be removed and foam does not have to be cut.
    My headrests were also stuck in the down position.
    First, try to loosen them up-push down, then up and repeat several times.
    Next use some lubrication-protect leather, push up the leather on the underside of the headrest and let several drops of WD-40 go down shaft. Move up and down repeatedly. You can also carefully use some plastic or nylon upholstery tools to use some leverage against the black grommet and the bottom of the headrest. Use caution and be patient. It also helps to have someone lifting the headrest as you do this.
    Eventually, the headrest should lift to the middle position. Now that the black grommet is exposed use some more lubricant and move the shaft up and down, but try not to lock it in the notches.
    Now to release the headrest. Raise headrest into the highest position. There are clips that can move toward the front which will allow you to pull up on the headrest which allows the clip to ride past the notches of the headrest rods.
    Put your palms on the top of the seat. You should be able to feel the clips by placing your thumbs approximately 2 1/2 inches down from the top and 1 1/2 inches toward the center from the centerline of the post. Keep feeling around and the clip will become obvious. Have someone pull up on the headrest as you push with your thumbs.
    When mine came out there was no indication or change in feeling of the clip. It just happened. One just came out. While the other one, I had one post loosen and rise a bit and then I worked on the other post and it came out.
    See the attached pictures of the pin at rest, pin compressed and the location of the clip.
    Good luck and instead of bruised and bloody knuckles now you will have sore thumbs for two days.
    It seems like a lot of work just to get a headrest out..and it is, but that is one of the many things we put up with to drive these cars.
  14. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    Joe. How did the black grommets come out?
  15. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    #15 stevel48, Oct 12, 2012
    It's funny that the owners manual states that these cars have adjustable headrests but provide no instructions on how to adjust them.
  16. jmaienza
    Jan 8, 2009
    628
    Massachusetts
    Joe
    As far as I can tell, it is just a press fit. I worked a plastic upholstery tool under the edge and gently used some leverage. Obviously, protect the leather. Once it comes out a bit, you can put some string, I use parachute cord, under the lip and use that to get some upward pull. You may also have to twist them back and forth initially to loosen the grip.
  17. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Thanks. I need to take it all apart for a redye
  18. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Success. No cutting or accessing the foam needed. I used the method above. Find the edge of the clip and push...push as hard as you can and the push a little more. One post at a time and it came right out. Soften your leather first so it has the stretch required to prevent damage. After its out just rub the leather with your hand to generate some heat and the indents from your thumbs will go away
  19. jmaienza
    Jan 8, 2009
    628
    Massachusetts
    Joe
    Steve,
    Glad it worked for you. I always thought that cutting the foam was always a silly solution. As quirky as these cars are, I always thought that even Ferrari would use a standard method of removing the headrest. I cannot imagine a factory tech cutting the foam and removing a clip to take the headrest off.
    One thing I have learned about working on these cars is that it takes a bit of thinking, figuring and planning before you tackle a project, whether its removing a headrest or refurbishing the rear suspension. Even though they are still just a car, they are not Chevys or Fords or BMWs; they"re Italian and have a way of their own... and in this day and age, that is a good thing.
  20. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
  21. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Once I knew how to get the headrest out after the first one, it took less than 20 seconds to get the 2nd one out. The key is to do one post at a time using two thumbs to press each pin forward while a friend pulls he headrest up. In my case, my wife.
    use the same method to adjust them up and down.
  22. chris_columbia
    chris_columbia Formula Junior
    858
    Columbia MD
    Chris
    The dimensions listed above by Joe were just perfect. Was able to get headrest out by myself. I did find it much easier to have the back panel off and slide hand under leather. I could easily feel the spring clip through the foam. I also ground at an angle the lowest detent on the headrest shaft, so I never have to do this again. Took about 5 seconds with a grinder. Looks really "factory" to me.
    As far as the black "sleeve"(grommets) that the headrest shafts slide into, I was able to pull those out with a threaded 7/16" bar, fairly easily. I bought a 3/8" thread eye hock based on Steve's suggestion above, but it was too small of a diameter to thread into the grommet. 1/2" was too big.
  23. Furryballer
    Furryballer Rookie
    Aug 26, 2013
    24
    Reading, UK
    Mark Borthwick
    Hey all,
    This is a very useful thread, so thank you for the info posted.
    However I've tried to remove mine, unclipped the leather and can find a clip on one side easily. The clip pushes forward freely, but the headrest just will not budge, not even a millimeter.
    I've now removed the clip altogether, but still nothing. Any tips?
  24. jmaienza
    Jan 8, 2009
    628
    Massachusetts
    Joe
    So both clips are out. The chrome shafts must be stuck to the plastic grommet. Try putting several drops of a penetrating oil on the shaft where it meets the plastic. Protect the leather because it will stain. After it has sunk in I would try a plastic upholstery tool to pry the headrest up. Try to find something that is long enough to give leverage and smooth enough so it doesn't permanently damage the leather. I would use some padding of some kind between the headrest and the top of the seat. While you "lever" it out, another person can try pulling it up at the same time. good luck
  25. Doc Chaz
    Doc Chaz Karting
    Mar 27, 2014
    124
    west of Fresno, CA
    Geez, just remove the 4 bolts anchoring the seat to the floor, and then take the entire seat to town..
