Heads up display | Page 2 | FerrariChat
Heads up display
Discussion in '296' started by BG259, Feb 22, 2023.
  1. ATLBond
    ATLBond Formula Junior
    Oct 30, 2021
    304
    Atlanta
    SR
    I’ll try that. The display is faint as you know.
  2. Ivan Drago
    Ivan Drago Formula 3
    Jul 14, 2021
    1,213
    Midwest
    Ivan Drago
    Appreciate it. I know it’s not easy so no rush on that. Thanks
  3. racerlev
    racerlev Rookie
    Dec 5, 2022
    15
  4. ATLBond
    Oct 30, 2021
    304
    Atlanta
    SR
  5. ATLBond
    Oct 30, 2021
    304
    Atlanta
    SR
    As u can see in the image, you can see both the severity of the turn caution and also the distance to the turn in.
    LVP488, Caeruleus11 and Ivan Drago like this.
  6. Ivan Drago
    Jul 14, 2021
    1,213
    Midwest
    Ivan Drago
    Thank you! That is so cool! I know that was a lot of work (as you described it even took many photo attempts), so I really appreciate it. I hope other members here find it as cool as I do.
    I saved it to my phone images. Thanks again, buddy!
    Caeruleus11 likes this.
  7. ATLBond
    Oct 30, 2021
    304
    Atlanta
    SR
    You are welcome, Ivan. FYI, the severity display works off the Car’s navigation system and you don’t have to choose any destination.
  8. cpd1
    cpd1 Karting
    Feb 2, 2015
    238
    CT
    C
    On the subject of GPS, do you have any issue with the GPS not loading? My car needs to sit for 2 minutes at the beginning of each drive to lock the signal otherwise it still thinks I am home when 25 miles away and never reacquires the signal.
    CarPlay works fine which is interesting since it feeds from car GPS so likely a software issue. Dealer told me it works as expected…:confused:
    I don’t use the satnav but as per above during drives on back roads, it is pretty useful to have the arrow/distance to turn.
  9. ATLBond
    Oct 30, 2021
    304
    Atlanta
    SR
    Car does take sometime to lock GPS signal but am not sure it takes 2 minutes. I have never faced the situation you are describing; GPS not locking signal and car assuming you are at start point still after 25 miles out. CarPlay navigation is independent of car’s nav / GPS system. Car’s antenna may boost the cell signal but does not give GPS data to iPhone. Your cars’ Sat nav software may need a dealer update or reset / reload or could be some other issue it sounds like. I am no expert in this matter but just speculating. All the best in getting it resolved.
  10. 4rextc
    4rextc Karting
    Nov 5, 2003
    180
    Madison, Georgia
    Stratton Hicky
    Just curious about the brightness issue. I know that polarized sunglasses can make a HUD display just about disappear, but you're saying even without sunglasses the HUD image is hard to see?
  11. ATLBond
    Oct 30, 2021
    304
    Atlanta
    SR
    Yep. The brightness of the display is low even at its brightest setting. I have HUD in my other car too and it is bright as heck day or night. BTW, Polarized glasses don’t seem to bother HUD these days.
    4rextc likes this.
  12. cpd1
    cpd1 Karting
    Feb 2, 2015
    238
    CT
    C
    Thanks for the feedback. It is definitely 2 minutes stop clock in hand, every time. Will book it in again, was told they updated the software but since no change, something is off.
    From all I have read, Wireless Carplay uses the car GPS if present, apparently a requirement for the implementation.
    IvanRico likes this.
  13. racerlev
    racerlev Rookie
    Dec 5, 2022
    15
    In addition to the HUD being not bright enough, my automatic wipers do not work, and the headlights do not turn off much of the day. I am beginning to suspect the sensor that sits behind the windshield. Anyone else have similar issues?
  14. ATLBond
    Oct 30, 2021
    304
    Atlanta
    SR
    Highly probable.
  15. Simon Pulsford
    Jul 26, 2014
    2
    I have a problem with the HUD in my 296. The system does not pick up the correct speed limit. I am told by Ferrari they are awaiting a fix, but it seems very slow to arrive...has anyone else experienced a similar problem?
  16. RamsHmb
    RamsHmb Formula 3
    1,212
    San Francisco
    James
    if press and hold the home key it will shrink car play back into a side screen and put the reffing counter back. Maybe everyone knows this but took me a couple of days to figure out and transformed my car play experience
  17. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    900
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    Yep, I discovered that too after a frustrating experience with multiple screens. My home button is still wonky as to when it will come on.
    RamsHmb likes this.
  18. RamsHmb
    RamsHmb Formula 3
    1,212
    San Francisco
    James
    May be a dumb ? But do you have the touch pad locked and need to wake it up. I have that setting on which is actually a godsend.
  19. BigJay2050
    BigJay2050 F1 Veteran
    7,191
    Wait, how do you turn this on/off and adjust the brightness? Which menu option is it under?
  20. Ivan Drago
    Jul 14, 2021
    1,213
    Midwest
    Ivan Drago
    Can dash brightness be turned down very low for night driving? I have read it is still very bright but maybe that person is unaware of how to do it, as it seems there are some "hidden" settings a few of you know about that others may not
  21. Ming the Merciless
    Oct 22, 2007
    2
    Dublin
    Justin Mckenna
    Mine doesn't show rev increases etc. Am I missing some setting?
  22. KL runner
    KL runner Formula Junior
    Jul 25, 2023
    654
    Not in US
    In HUD settings change the setting from classic to race
    PieGre likes this.
  23. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,162
    can you turn it off?
  24. KL runner
    Jul 25, 2023
    654
    Not in US
    I do not think you can but by adjusting the position of it and the brightness you could probably render it useless
