Heads-up on trans/diff oil on 612... | FerrariChat
Discussion in '612/599' started by trygve11, Oct 30, 2015.
  1. trygve11
    trygve11 Formula Junior
    740
    Kansas City
    Jason Hagen
    I am a dedicated Amsoil proponent. Pretty much all I use.
    That being said, when I built (rebuilt) my 612, I changed the tranny and diff fluid with the Amsoil 75w90 Severe Gear product. I have used it in all my Alfas and my Maserati QP.
    Turns out that my diff is "chattering" when starting from a stop and turning at the same time. It appears that though the product says it works fine as is for most limited slips, Amsoil states that if you experience chatter, you need to add their AMSOIL Slip-Lock™ friction modifier additive.
    I will try adding that and report back if the issue is resolved!
  2. tazandjan
    39,323
    Jason- Add very small amounts until the chattering stops. Like an ounce at a time. Too much and you will make the synchros too slippery to do their job and you will start getting graunching. Incidentally, Valvoline synthetic 75W90 does not chatter in my 575M with essentially the same transaxle.
  3. trygve11
    740
    Kansas City
    Jason Hagen
    Taz, that is great advice. Thank you.
    They recommend 4 ounces and suggest that will do 2 to 4 qts. The manual suggests it holds some like 5 liters. I think you only really get out about 3 and some change but probably get more if you blow out the cooler.
    Do you think maybe start with 2 ounces or do the 4 ounce tube (it comes in four ounce tubes)?
  4. BigTex
    79,407
    Houston, Texas
    Bubba
    Totally different (but similar) was the whale oil additive to GM positractions.
    It did not take much.......seriously.
    It was a one or at most two ounces, but of course did not have that kind of volume.
  5. tazandjan
    39,323
    Jason- I would start with one ounce. You do not want any more in there than it takes to do the job. May be a little more work that way, but too much is way too much.
  6. trygve11
    740
    Kansas City
    Jason Hagen
    Yeah, I figure if I tune it for "just enough" with the cold weather, it will be flawless in the warmer weather. Check my logic...
  7. Piper
    Piper Two Time F1 World Champ
    Jun 6, 2010
    25,415
    Northern Virginia
    Bob
    Taz, what's graunching?
  8. tazandjan
    39,323
    Bob- That is the noise the gears make if they are not properly meshing. Grinding might be a good synonym. If you have driven non-synchro boxes, the noise most low timers make when they shift gears.
