Heat Exchanger Failuer | Page 2 | FerrariChat
Discussion in '360/430' started by goachild2000, Oct 20, 2014.
  1. one4torque
    one4torque F1 Veteran
    5,783
    Houston
    One4torque
    How much is a trans rebuild?
    Assuming I remove it and ship it myself.
    5$k. 10k$
    my t56 rebuild was $2900 for a performance road racing rebuild. For reference.
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,606
    Charleston, SC
    Curt
    I like this post. :)
    NMNMNMN likes this.
  3. lkstaack
    lkstaack Formula Junior
    Dec 9, 2020
    252
    San Diego
    Lars
    I just replaced my heat exchanger. Here are some lessons learned:
    • Be prepared with allen head screw extractors. Two of the allen head screws used to fasten the water pump body snapped.
    • Use the OE wide clamps for tightening the rubber sleeves at the end of the HE. The replacement clamps I received from both Ricambi and Eurospares were too narrow. They tended to tighten at an angle that I feel would result in uneven tension around the HE. Although I couldn't feel that they were at an angle, an inspection with a mirror showed that they were, and when I removed them, the worm gear slots were worn to an extent that I wouldn't have reused them. The original clamps provide a more even tension and are the style used for forced induction purposes. Mine were in good shape, so I reused them.
    • I spent the big bucks for new rubber sleeves. However, my old sleeves seemed to be perfectly fine. I probably should have inspected the old sleeves before I bought new ones.
    • Do not tighten the HE clamps until you fasten trans oil lines to the transaxle. They must be installed at the correct angle to the transaxle, and the braided lines have very little give. You will probably have to turn the HE one way or the other to get the proper angle. Then, tighten the clamps.
    I'll probably write a complete narrative later.
  4. mdileo
    mdileo Karting
    Jan 27, 2015
    61
    Nyc
    Max
    thank you so much for the tips its all getting done this Sunday! I am very interested to see if just the coolant system was contaminated and not the trans or rear . I had no problems shifting but we will see. I had a major done very recently to add! And my fans do not turn on at all by the way. Its gonna be a long sunday!
  5. 24000rpm
    24000rpm F1 Rookie
    fan doesn't turn usually = air in coolant.
  6. 74dino246gts
    74dino246gts Karting
    Aug 6, 2004
    126
    Northern California
    I did mine last February. I inspected the HX prior to installation and found a slight amount of debris in the tubes, that was easily removed with a brush and compressed air. I also thought that using brake clean to clean the tubes and tube sheet would be a good idea. Big mistake. The brake cleaner dissolved some of the coating - the drip pan I used to collect the waste brake clean was coated in a copper/gold residue. Thinking that I just ruined the HX, I emailed the factory in Italy. Fortunately, I learned that the coating is just applied for aesthetics and no damage was done. I also installed new washers for the oil lines. They are very pricey, but I didn't want to have to do the job twice.
    Qavion likes this.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,003
    Isle of man- uk
    You can get tube cleaning brushes specially for these types of coolers.
  8. mdileo
    mdileo Karting
    Jan 27, 2015
    61
    Nyc
    Max
    Well i have an update!!
    loads of coolant in the rear and gearbox!!
    Recently coolant was added at major that i just did 2 months ago .
    I want to change the thermostat since we are in there . Heres a great question what thermostat can i buy that matches looks pretty standard to me will post a pic when i go grab it from the shop. Or is there an interchangeable part number anyone knows of.?
    and i dont think it did any damage to my rear or gearbox thank god!! Then again was shifting fine! I will definitely be taking a close inspection left it all open to dry out .
  9. lkstaack
    Dec 9, 2020
    252
    San Diego
    Lars
    Unfortunately, there isn't a certain method for ridding the transaxle from liquid contaminates. The consensus is multiple fills and drains; I doubt leaving the fill and drain plugs open will do much. I've drained mine two times and it isn't even off the stands yet. There are many opinions about what to fill the transaxle up with for flushing contaminates out. My first fill was 1 qt ATF, 1 pt isopropyl, and the rest 80w-90 gear oil. The second and third is just cheap 80w-90. I'll be driving about 50 miles with my current fill, and the next, and hopefully last, will be Redline.
    Have you checked the transaxle filter? The filter during my first drain was coated with what looked like fine black gravel (I have no idea when the last time it was pulled and cleaned was). The second didn't have any, but the third had a little of the gravel-like contaminant. I hope that it wasn't synchro shards.
    You haven't mentioned anything about your coolant. I didn't think that any gear oil got into my coolant. However, I noticed the faintest sheen of oil, only noticed in direct sunlight, during my 1st and 2nd coolant flush. I've since flushed it twice more. Unfortunately, draining the radiators and blowing the lines with compressed air only removes about half of the coolant. Even after flushing the system four times with 100% distilled water, there was still visible signs of coolant in the system.
    My water pump housing hose bibs were corroded with a thick green buildup that required an abrasive to get off. Probably indicative of the infrequency of coolant changes. I fear that my radiators have something similar.
  10. Skippr1999
    Skippr1999 F1 Rookie
    4,567
    I’m going to get my HE replaced during a major this Summer.
    Are you guys replacing with the OEM exchanger, or is there a upgraded unit made by someone else (Hill Engineering ?)
    Thanks.
  11. lkstaack
    Dec 9, 2020
    252
    San Diego
    Lars
    There's nothing else. I guess we're lucky that Ferrari is still making them. My HE was only a few months old.
  12. mdileo
    mdileo Karting
    Jan 27, 2015
    61
    Nyc
    Max
    Wait stop yes there is a after market option by a company that separates both i have posted about the company before on the forum . https://www.dynamtechgroup.com/ferrari-tranny-cooler.php
  13. mdileo
    mdileo Karting
    Jan 27, 2015
    61
    Nyc
    Max
  14. mdileo
    mdileo Karting
    Jan 27, 2015
    61
    Nyc
    Max
    i posted some pictures already showing loads of oil in the coolant already. Im pretty far up the creek without a paddle boys .
    Anyway its still a work in progress i do have my guys working on it and not myself I decided to not go at this alone as it entailed alot .
  15. mdileo
    mdileo Karting
    Jan 27, 2015
    61
    Nyc
    Max
    I was told for the coolant side of things that along with a vaccum ...dawn soap actually to help break up the oil believe it or not . As for the gearbox and rear oil side im still exploring options but either way multiple fills and flushes on both ends seem inevitable.
  16. mdileo
    mdileo Karting
    Jan 27, 2015
    61
    Nyc
    Max
  17. mdileo
    mdileo Karting
    Jan 27, 2015
    61
    Nyc
    Max
    Surprisingly tho the transmission feels ok when shifting no noise . When i gave it the short quick drive over to my shop location. Trust me I didn’t want to do it being aware of the situation but you try getting a tow truck guy locally for 8 am on a sunday in queens nyc ! .... good luck my friend lol.
  18. mdileo
    mdileo Karting
    Jan 27, 2015
    61
    Nyc
    Max
    What i still can’t believe are the prices for those rubber sleeves i mean cmon really . I usually don’t complain about prices but at at least 250 from recambi for a sleeve even with a discount. Seems a little blatantly laughable.. its just rubber plastic and i didn’t receive new clamps either!? Some guys say they do and the just use the old ones because they are wider and seal better but whatever.
  19. lkstaack
    Dec 9, 2020
    252
    San Diego
    Lars
    Yes, I did in post 28, above. And, if your experience mirrors mine, you won't even need those expensive rubber sleeves.
    Sent from my SM-G781U using FerrariChat.com mobile app
    mdileo likes this.
  20. mdileo
    mdileo Karting
    Jan 27, 2015
    61
    Nyc
    Max
    im guessing you can get them somewhere else cheaper. Im open to hear about alternatives for future reference regarding the sleeves. I mean, I’m no ferrari guru . But i learn quick and i am very mechanically inclined.
  21. mdileo
    mdileo Karting
    Jan 27, 2015
    61
    Nyc
    Max
    I can say i am blessed to have some very very experienced ferrari old timers around me.
  22. grtoz
    grtoz Karting
    Dec 14, 2010
    165
    Byron Bay, Australia
    Graeme Towers
  23. grtoz
    grtoz Karting
    Dec 14, 2010
    165
    Graeme Towers
    Qavion likes this.
  24. NMNMNMN
    NMNMNMN Formula Junior
    I have been around marine engines for many years and I have to say that the HX pictured looks like a gear cooler off of a marine engine.
    I would bet money you could get a gear cooler that works very easy and inexpensively.
  25. 24000rpm
    24000rpm F1 Rookie
