Heat Insulated Windshield | FerrariChat
Discussion in 'FF/Lusso' started by NeilF8888, Oct 6, 2016.
  1. NeilF8888
    NeilF8888 Formula 3
    Feb 10, 2005
    1,174
    Miami Beach
    I am thinking about ordering the Heat Insulated Windshield for my GTC Lusso as it will be my daily driver here in South Florida. I don't want to put a tint or plastic over my windscreen. Other than the slight weight increase, which I don't care about on the Lusso and the cost, are there any negatives and does it really make a difference inside the car? Does anyone have any personal experience with the Heat Insulated Windshield?
  2. iohead
    iohead Karting
    Feb 19, 2013
    174
    Negatives:
    * Cost (last I checked, ~$1200 on the F12 in the US)
    * Weight penalty (never seen a quantification, but can't be too bad)
    Positives:
    * Reduces heat coming into the cabin by 50% (I did see a quantification)
  3. NeilF8888
    NeilF8888 Formula 3
    Feb 10, 2005
    1,174
    Miami Beach
    Does it lower night vision or any other negatives? If not, it seems like no brainer in hot climates.
  4. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    I've had it on our last few cars. To me, it's a no brainer. I think it might add 1-2kg.
    It works really well, and have had zero issues with night visibility, interference with electronics, et al. For Florida, it would definitely help, given the size of the windshields and the rake angle.
  5. iohead
    iohead Karting
    Feb 19, 2013
    174
    No other negatives that I know of. I've had it on every car so far, and would spec again.
  6. BMan14
    BMan14 Karting
    246
    Does it not affect radar detector functionality? Had major issues with the glass in my S63...
  7. rockitman
    rockitman F1 Veteran
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    I was inquiring when I spec'd my car if the insulated window was harder, more impervious to chips. It's not from what I gather. If my car spent a lot of time outdoors and/or I lived in a hot and sunny climate, I would get it for sure.
  8. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    it's not a HEATED windshield, so it doesn't have any metallization/wiring inside...like our Cayenne which does and renders EZ-Pass transponders, et al useless.
    The heat insulation I believe is a UV laminate layered in. Not tinted (at least that I can tell) but UV shielded, and it works pretty well
    I have put a protective laminate on a couple cars, if installed properly they work great and save the windshield from pitting for sure
  9. NeilF8888
    NeilF8888 Formula 3
    Feb 10, 2005
    1,174
    Miami Beach
    Does ez pass etc work with heat insulated windshield ?
  10. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    I have the heat insulating windscreen on my Cali, and have not had any trouble with our Toll Tag (Texas version of the EZ Pass) registering...T
  11. otakki
    otakki Formula 3
    1,634
    Personally, I would go this route. The factory one likely has the laminate sandwiched and thus wouldn't do anything to help with the pitting.
    BTW, how much did it cost to protective laminate the windshield?
  12. rgdonnan
    rgdonnan Rookie
    Sep 18, 2010
    47
    SW FL USA
    R Donnan
    I've had it on two (2) previous Californias and now on my F12. There is no negative effect on radar detector sensitivity or functionality. I have also used EZPass and SunPass toll transponders through the windshields.
  13. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    I had it done when we had the 3M done, IIRC it was around $600, and in our case, was not the UV film. The material is quite different than the paint protection film, and it's pain in the ass to install perfectly.
    contrast that with tear offs on race cars, which cost a few hundred to install, but bubbles are somewhat tolerated
  14. Caeruleus11
    Caeruleus11 F1 World Champ
    11,604
    #14 Caeruleus11, Oct 6, 2016
    I've had it now on 2 cars and absolutely no issues with night viewing, radar, EZ pass, etc. Highly recommend it for just about anyone. I should add, as a comparison, there was a noticeable difference between my 458 with the heat insulating windshield and my friend's 458 without. He would always say the AC in his 458 was not very good. One day I went to check it out- it basically felt like we had to run the AC one notch more than I had to in my car. Same car, same AC, just different windshield.... IMHO well worth it.
  15. ferraribrit
    ferraribrit Karting
    Feb 27, 2009
    159
    Ridgeland, MS
    Paul
    I had it on my first F12 (here in Mississippi) and didn't bother ordering it on the 2nd one as I couldn't tell any difference. Just my 2 cents.
    Best, Paul
  16. Solid State
    Solid State F1 World Champ
    10,568
    Maximus Decimus Meridius
    One would think that all windshields are laminates and UV blocking film is just a simple coating so I'm impressed that its a $1200 option but not really surprised given the cost of cup holders these days. Heat and radiation are very damaging to fine materials over time so should be standard and not an option IMO.
  17. PhantomCypher
    PhantomCypher Formula Junior
    May 25, 2014
    281
    That's the first thing I thought of as I avoided at least 8 different highway patrols with my trusty radar just today alone.
  18. NeilF8888
    NeilF8888 Formula 3
    Feb 10, 2005
    1,174
    Miami Beach
    Are radar detectors effected by Heat Insulated Windshields on Ferraris?
  19. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    Yes have personal experience
    Not affected. In contrast the electrically heated windshields (not offered on Ferraris) DO affect and limit RF signals. Even on those types there is typically a null zone on the glass specifically for transponders/tags.
  20. NeilF8888
    NeilF8888 Formula 3
    Feb 10, 2005
    1,174
    Miami Beach
    Thanks everyone for your guidance, just amended my GTC Lusso order to include the Heat Insulated Windshield and was told it will be a December production.
    Elegante likes this.
  21. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    since you're in FL and spending option money...did you go for privacy glass, or will you tint the windows? just curious. am tempted to do a tint on our most recent car since the back glass is almost flat and the quarter windows are 4 square inches
    in hindsight, should have just paid for the darker glass
  22. NeilF8888
    NeilF8888 Formula 3
    Feb 10, 2005
    1,174
    Miami Beach
    I find tinting the driver and passenger front windows really effect my night vision and a few years ago after almost hitting a bicyclist I had them removed from my vehicles. That being said, I don't like the mixed light front side window and the darkened rear side window contrast effect. Its not bad on a SUV but unbalances the look on a GT or sports car.
  23. otakki
    otakki Formula 3
    1,634
    Where are you at, with so many cops around? It's not Huntington Beach, is it?...But I have heard there are no longer many cops around in Cali.
