Heat shield thingy | FerrariChat
Heat shield thingy
Discussion in '308/328' started by Pizzaman Chris, Aug 25, 2013.
  1. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    I was going thru my box of unused parts when I stumbled on this piece i forgot to install.
    I found Newman's picture of it installed but that's with the motor out. I can't remember if this goes in easy or will i need to take a day off from work to get her done.
  2. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Just did my alternator '82 GTSi this heat shield is the front shield by the alt. I pulled the aluminum water pipe from the water pump and the shield slides in easier. Just put a pan under the lower slip joint and let the coolent drain. Hope this helps. Rgds Wayne
  3. pgarossino
    pgarossino Formula Junior
    Nov 19, 2009
    307
    Houston Tx
    Paul G.A. Garossino
    If you take the two pieces apart first, they go in pretty easy without moving anything about. Getting to the two bolts to put them back in, once the pieces are in place, is pretty easy to do from underneath.
    Good luck,
    Paul
  4. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    This.
  5. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    This sounds like a easier approach. Thanks Paul.
  6. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,301
    Ventura, California
    Robert Garven
    #6 robertgarven, Aug 27, 2013
  7. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Rob,
    Thanks for the detail pictures. After seeing them, now I know its important to put back in.
    Your cars all apart again?? What the hey?? Where's the thread on this project?
    Cactus gardening? You crack me up Rob.
  8. enzo777enzo
    enzo777enzo Rookie
    Oct 29, 2013
    43
    Argentina - La Pampa
    hello
    i buy my car a not have heat shield in manifold.- I want made theys (2) in hard alumine.-
    Please.- Can someone send pics of shields??? and measures??
    Regards
    Enzo
  9. robertgarven
    Feb 24, 2002
    5,301
    Ventura, California
    Robert Garven
  10. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
  11. robertgarven
    Feb 24, 2002
    5,301
    Ventura, California
    Robert Garven
    Chris,
    I think yours is different than my GT4's at least in looks.
    Rob
  12. enzo777enzo
    enzo777enzo Rookie
    Oct 29, 2013
    43
    Hello
    thanks Robertgarven and Pizzaman Chris
    my car is Euro 208
    like Robert you attachd in this treaths in post 13 ( https://www.ferrarichat.com/forum/308-328/295274-heat-shields.html#post143108355 )
    Now i can import, our goverment, not permit we spend my money out side of country.- And not permit post import any item to Argentina.- (it like Cuba or Venezuela ...:( )
    I shoud make them
    regards
    Enzo
