heat shields | FerrariChat
heat shields
Discussion in '206/246' started by GermanDino, Dec 7, 2013.
  1. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    #1 GermanDino, Dec 7, 2013
    I´m loking for good quality/fitting heat shields for my Nart-Dino #00306
    No. 7, 12, 16 and 20
    206 GT and L-series heat shields are the same. No. 12 and 20 can also be found on M- and E-series...
    What I have seen from DinoParts and Superformance isn`t perfect.
    Can anybody help?
    Regards Matthias
  2. swift53
    swift53 F1 Veteran
    8,356
    E.S.
    Alberto
    Matthias, do you have quality photos and dimensions?
    Regards, Alberto
  3. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    no heat shields came with #00306, to remove them from my other cars is what I want to avoid...
  4. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Mine are all off my 206. Maybe I can help.
  5. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    yes, pictures from front and backside would be great...
    also measurements in mm if possible
    and/or perfectly original reproductions....
    regards Matthias
  6. pshoejberg
    pshoejberg Formula 3
    1,837
    Denmark
    Peter H
    I'm also preparing fabrication of all the heat shields for my 246 L series and would very much appreciate some good pictures and / or drawings with all major measurements on. I have used the search function a lot and haven't found any good descriptions of the complete shield configuration for these early cars.
    Best regards
    Peter
  7. swift53
    swift53 F1 Veteran
    8,356
    E.S.
    Alberto
    I have some and missing some, for my L series. Let's pool resources and come up with a definitive list with dimensions and shapes.
    Regards, Alberto
  8. HMB-Dino
    HMB-Dino Formula 3
    2,295
    Pebble Beach, CA
    RonG
    It looks like the only diff between your No 16 and TAV13 No 2 for an M-series is the location of the bottom right mounting hole...everything else looks identical. Is that your understanding as well?
  9. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    I will dig everything out on Monday and report back.
  10. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    I have original 12 & 20 off the car which could be used to template and would like a high quality set of replicas for 7 & 20 (the two mounted on the exhaust systems).
    … was planning to fabricate these but can't do anything until 2014.
  11. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    looks like from the drawings, but not sure.....
    sturrisi likes this.
  12. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    great, thanks Jon
  13. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    I have 16 available for measure and photos, if useful
  14. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    Hello Jon & Luigi,
    can you post your pictures here please.
    Regards Matthias
  15. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
  16. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #16 omgjon, Dec 14, 2013
  17. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    thanks Jon and Luigi...
    Jon, are the two small ones are actually the same through all series?
  18. rynoshark
    rynoshark Formula 3
    1,034
    Pacific Northwest
    Superperformance produces all five of the heat shields. Are they all lacking or are some of them pretty close?
    Exhaust Parts for Ferrari 206 & 246 - Superformance
    Their Driveshaft Heat Shield #20538 looks pretty close to original in their photo. Rivets on the Superperformance Alternator Heat Shield #300027 appear to be incorrect (and likely no interior insulation.
  19. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    I stillhave my old ones but need to recover with some sort of heat resistant material....what does one use nowdays ?? and where to buy in EU
  20. swift53
    swift53 F1 Veteran
    8,356
    E.S.
    Alberto
    I bought some material you mention for the exhaust of an Alfa.
    But then, I do not know what the stuff was made of, most likely asbestos, but then of course
    we do not have any laws concerning that stuff, or possibly they have passed something to
    that effect. :)
    I am certain there has to be something you can use in EU.
    Regards, Alberto
  21. dman550
    dman550 Karting
    Dec 17, 2012
    111
    White Rock BC
    Dario
    This thread was a great help for me to identify a part that came with my car which I wasn't sure where it went. Well I find it's a heat shield. Specifically number 16.
    Which brings me to my question. This piece has only one tab that is riveted to it. Mine is broken off. Can someone get me a length for this piece and the size of the hole that is in it. I know the width due to the tab left on the heat shield itself.
    Also,
    Mine heat shield still has a finish which looks original. It is black with the similar wrinkle paint like what is on the steering column. Does this sound correct?
    Thanks.
  22. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #22 synchro, Mar 23, 2014
    Tavola 12, Item 16 is a nut. I'll bet you mean 6
    Note: always makes it easy on the viewer to post an image from the parts book when asking questions. I know you have a parts book, I gave it to you at the Dino party last week! :)
    See attached
  23. dman550
    dman550 Karting
    Dec 17, 2012
    111
    White Rock BC
    Dario
    According to your drawing I meant #2. The largest one. I'll take a picture of it tomorrow and post it.
    Thanks. I should have referenced the book :)
    Dario
  24. dman550
    dman550 Karting
    Dec 17, 2012
    111
    White Rock BC
    Dario
    #24 dman550, Mar 24, 2014
  25. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,335
    Iain
    #25 isuk, Mar 24, 2014
