heater and ac 360 spider | FerrariChat
Discussion in '360/430' started by star55, Oct 28, 2011.
  1. star55
    star55 Karting
    Jun 24, 2011
    141
    hey guys my heater doesnt work for some reason its get around 2-10C celsius up in toronto these days when i want to pull my ferrari out at night time after like 40 - 1 hour it might throw a bit hotter air but nonetheless it throws cold air and the ac doesnt work either in summer time .. what can i do for the heater around this time of the air what do you think is the problem the car is from california and i dont think they ever turned the heater on in it.. i think its a minor fluid issue but please advise
    thank you
  2. F1.360.LOVER
    F1.360.LOVER Formula Junior
    Dec 12, 2009
    476
    Central Florida
    Nate
    I don't want to offend you but I'm going to assume that you know what the STOP button function is. If you do, I would take it in to a shop and have them look at it.
    Nate
  3. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    #3 Spitfire, Oct 28, 2011
    Make sure your STOP button is in the out position. The design of this part of the system is confusing.
    Putting STOP into the in position stops the climate control from working = no cooling and no heating.
    Leaving STOP in the out position allows the climate control to work properly and apply heat and cold. Leave it in this position as it takes a minute or so for everything to work properly. In other words, if you keep pressing it in and out quickly you won't get an accurate feeling for how it works.
  4. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    Is the a/c compressor on when the stop button is in out position?
    I hardly use the climate control because I always leave the windows down to hear the sound.
  5. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,455
    Dublin, Ireland
    Greg
    It's possible you have no coolant in the "radiator" of the heating system. This could be due to a blockage, low level of coolant, an air lock etc.
    How is your coolant level? Does the temperature gauge work ok and give realistic readings? Is the fan on the ventilation system coming on good and strong?
  6. Skidkid
    Skidkid F1 Veteran
    9,596
    Campbell, CA
    John Zornes
    That's the one that I would go for. It can be too low to run the heater but still show a temp on the guage.
    The stop button is on/off for the climate control. If it is off there is no heat or cooling.
  7. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    that's right you must run the heater at max during bleeding procedure.
  8. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Yes:
    Button out = climate control ON
    Button in = climate control STOPPED
    It's a confusing system I think.
  9. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    is the AC compressor always active even in cold weather? or does it kick in only above certain temperature?
  10. FerrariDublin
    Jun 14, 2009
    3,455
    Dublin, Ireland
    Greg
    Not "always" active in cold but it will cycle to assist in condensation clearance.
  11. GhostByte
    GhostByte Karting
    Jun 12, 2011
    205
    Toronto
    Daniel T
    Hey man swing my place I will show you
    I guess I am not the only NUT driving in Toronto in the cold weather :-?
  12. star55
    star55 Karting
    Jun 24, 2011
    141
    i feel soo stupid now the stop was ON
    i turned it off and the heating starting working :)
    thanks guys
  13. FerrariDublin
    Jun 14, 2009
    3,455
    Dublin, Ireland
    Greg
    I salute you honesty! Well done. :D
    Glad you're sorted too!
  14. Skidkid
    Skidkid F1 Veteran
    9,596
    Campbell, CA
    John Zornes
    We have all done it at least one and maybe more. I your car has been parked or you havne't driven it in a long time you can forget if you wan it in or out and then ... you get the idea.
    Glad it worked out easily
  15. F1.360.LOVER
    Dec 12, 2009
    476
    Central Florida
    Nate
    Don't feel stupid. I found out about the stop button by accident. It took me forever to remember how to open the trunk just to get the owners manual out to read about the stupid button. Glad it all worked out.
  16. AVHS2934
    AVHS2934 Rookie
    Aug 29, 2011
    3
    All This time I thought it was just to shut off the A/c compressor only. Learn something new everyday. Cheers!
  17. jpk
    jpk Formula Junior
    Anyone know how to make sure no accessory fans or climate control features are on at all? I know the STOP button stops heat and A/C, but usually I even want to stop the blower. I have been putting the fan speed control on the right to the "fan" symbol since the I, II, III, IV symbols clearly mean the fan is on and running low to high speed. But I sometimes still feel like air is blowing through the system even when I put it on the "fan" symbol. Anything else to make sure no fans are running?
