Heater Blowers | FerrariChat
Heater Blowers
Discussion in '308/328' started by rkljr, Feb 26, 2016.
  1. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    At the end of the fall, I noted one of my heater blowers was not working. Or should I say my wife noticed. Yesterday, I opened up the wheel wells and found that one had come off its mount and disconnected itself. I also looked at the other and although the electrical connection was intact, it was partially separated from the mount.
    Upon removing both blowers, I noted they each had one mounting point broken off. It appears that one of the screws comes loose causing the unit to pull away on one side resulting in a broken mount on the other side.
    If you have not had this problem yet, I suspect it will happen to most every car at some point, I suggest you pull of the front wheel well shield (four screws) and ensure the two screws securing the blower are tight.
    You can buy new blowers but I opted to repair mine. In addition, when I reinstalled them I used bolts instead of screws. As I suspected, they used screws because there is not much room to work in there and putting the bolts on was a PITA.
  2. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    628
    Massachusetts
    Joe
    The plastic mounting tabs are one of those annoying features of the 308. the plastic will break eventually. Essentially the whole unit pivots off these two top tabs which pretty much insures that they will crack.
    I reinforced the tabs and added a reinforcement bracket to minimize the top to bottom swaying. This bracket really stabilizes the unit and does not require new holes. Here is the link.
    http://www.ferrarichat.com/forum/308-328-sponsored-yellow-compass-group/402598-heater-fan-mounting-reinforcement.html
  3. rkljr
    May 16, 2011
    723
    South of Boston, MA
    Richard
    I too reinforced the plastic tabs. I thought about providing additional support and I like your solution. In the end, I figured if it lasted 30+ years, my repair should last another 30.
    I think a lot of the problem is when one screw comes loose, it causes the other side to flex and crack. At least that is the diagnosis from examining my two blowers.
  4. Labman
    Labman F1 Rookie
    3,801
    Long Island, NY
    Steve
    I refastened mine with zip ties after I noticed both blowers mounting tabs broke. It is going nowhere now. Perfect and easy fix.
  5. rkljr
    May 16, 2011
    723
    South of Boston, MA
    Richard
    Another interesting solution, simple, flexible, and easy to replace if they do break.
  6. chris_columbia
    chris_columbia Formula Junior
    868
    Columbia MD
    Chris
    Most are broken, but they just sit on the "floor" of the front valance, so most people don't notice. If you look thru the front vents on a car you can usually see the fan housing sitting on the floor, unless it has already been fixed.
    Great way to piss off a new owner. Look down the front vents and tell them their fans are broken off.
