Heater control layout - car vs. manual | FerrariChat
Discussion in '308/328' started by ramosel, Oct 17, 2009.
  1. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    #1 ramosel, Oct 17, 2009
    I've been rebuilding/recovering my center console. I took lots of pictures so I could put it all back together correctly and positioned my cable controls left to right as 2 temp controls then 2 def/heat controls. As far as I can remember, every car I've seen is laid out this way. The picture below I recently took when John Youngdahl came by so I know I'm not halucinating or working with bad memories (I am recovering from a head injury?!?).
    I had reason to look something up in my owner's manual yesterday and I came across the drawing of the heater controls (1980, Page 44) - But in a different orientation. It's something I never caught before. After looking at it a bit, its sort of an early version of zone control and letting the passenger select their heat level.
    Did any cars come from the factory set up as in the manual? Has anyone done this? I mean its a simple fix to move the bezels and cable holders on the backside. I think I actually like the manual's setup better.
    Rick
  2. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Mine were per OM (left temp/def - right temp/def). When one bezel broke, I replaced all 4 with Verrel's plus installed new cables, and noted there is a subtle but important difference between the underside lever for temp and def. Best get those right to get the proper full cable travel.
  3. BigTex
    79,386
    Houston, Texas
    Bubba
    I dunno..my far right one is the Choke...
  4. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    #4 ramosel, Oct 17, 2009
    Thanks! Yeah, those were duly noted in my pre-disassembly pictures. Not only are the levers different length but the cable holders have different positions and angles. I think because I was so in tune with getting those positions right is why the picture in the manual suddenly looked different.
    Rick
