Heater control switch 328 part number 6188300 | FerrariChat
Discussion in '308/328' started by TheMayor, Nov 12, 2024.
  1. TheMayor
    106,236
    Vegas baby
    Mine on the passenger side is stuck. Its just the micro switch worn out. A replacement is just stupidly priced. Anyone know someone who fixes these?
  2. JV's89
    JV's89 F1 Veteran
    7,304
    Pittsburgh, PA
    Maybe reach out to O.D.D Parts.
    I was talking to them last year about my heating/ac control issues and they were working on solutions for another customer with similar problems.
  3. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,262
    Worcester, England
    Phill J
    No idea who might fix them, but the part number should be 61808300
    @ $3000 new (but not available), @ $1275 ~ $2030 used, depending on condition.
    The heater control switches are just one of those parts you can see are all but guaranteed to fail sooner or later :(
    TheMayor likes this.
  4. Sigmacars
    Sigmacars Formula 3
    1,220
    Yes take the switch out and resolder the contacts this was my problem the lights would not move 2 wires came loose working fine now
  5. Skippr1999
    Skippr1999 F1 Rookie
    4,514
    On my switch one of the lights stays illuminated. It’s the first light. Does anybody know why this one light stays on. Otherwise, the switch works fine. All the lights will illuminate as you press the button, but when you try to turn all the lights off, the very first light stays on
  6. Rifledriver
    37,121
    The lights go one or come off as feed back from rotary contacts on the heater valves and air ducts. They can get out of sync or the valves and ducts can be restricted in movement. There are access holes on the back to adjust pots to sync them.
  7. Skippr1999
    4,514
    Thanks Brian. Much appreciated.
  8. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    391
    Herts, UK
    Richard
    This is a useful document for calibrating the lights.....
    Zenobie likes this.
  9. Skippr1999
    4,514
    Excellent. Thanks for posting
  10. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    Are there internal contacts that may be cleaned? replacing at $3000 is much!
    On many switches I squirt Wurth OL 'De-Oxidizer spray and it cleans so much
  11. mixedgas
    mixedgas Formula Junior
    275
    Ramona, CA
    not to be a total jerk, but I'm felling pretty smug about my choice of 308 instead of 328 right about now... :)
    ChevyDave, miketuason and TheMayor like this.
  12. TheMayor
    106,236
    Vegas baby
    We did try that. I'm going to try again.
    Sergio Tavares likes this.
  13. mixedgas
    275
    Ramona, CA
    I feel like I should provide some value to offset my snark; I've repaired dozens of switches in my old bentley using this (DeOxit 5): Image Unavailable, Please Login
  14. dinos
    dinos Karting
    Jan 6, 2013
    107
    Athens - Greece
    Dinos
    I have the same problem! (The lights go to the full and can come back to 2 lights, but never to off) do I need to remove the switches before spraying the cleaner? If so, could you provide any information or instructions on how to remove them?.
  15. TheMayor
    106,236
    Vegas baby
    WOW I just bought that exact stuff 2 days ago. Should arrive on Tuesday. I have 3 total switches. One works perfect, one has a problem opening and one has a problem closing. To me its just a contact problem.
    I'll report if it helps.
    Sergio Tavares and mixedgas like this.
  16. Alden
    Alden F1 Rookie
    3,626
    Central Florida
    Been using Deoxit on all the switches, contacts and connectors on my car for years! It's great stuff!
    Alden
    Sergio Tavares and TheMayor like this.
  17. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,262
    Worcester, England
    Phill J
    Because 308's never suffer heater control issues, such as seized cables? :confused:
    dflett and Rifledriver like this.
  18. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    Can you remove and disassemble?
  19. TheMayor
    106,236
    Vegas baby
    Yes I saw the micro switches under the cover. I’ll try to spray them on Wednesday.
  20. Skippr1999
    4,514
    Are you guys spraying Deoxit directly into the interior of the switches, through the crevices?
  21. Alden
    Alden F1 Rookie
    3,626
    Central Florida
    That can be done, that's the way I do it as a maintenance item, but the switch can also be removed and the contacts sprayed directly.
    Alden
  22. Skippr1999
    4,514
    Thanks for your reply. I believe my contacts are already clean, but was wondering if there were things inside the switch casing itself that needed to be sprayed
  23. Alden
    Alden F1 Rookie
    3,626
    Central Florida
    I think it really depends on the construction of the switch, and whether or not the contacts are easily accessible without removal or disassembly, so far all my switches are working fine, even better after I spray them with deoxit, so I guess it's getting in there.
    Alden
    Sergio Tavares and Skippr1999 like this.
  24. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    Please recall these switches face up and catch every dusty dirt over the last 40 years and it gets in the switch. Not like dash vertical switches these are positioned to catch it
    When i removed the frunk cover to watch the slide switch activate the heater valve it was quite cool but to complicated imho
    Skippr1999 likes this.
  25. Skippr1999
    4,514
    Are you guys also spraying the electrical parts of the heat valve underneath the frunk ?
