Heater control switch 328 part number 6188300 | Page 2 | FerrariChat
Discussion in '308/328' started by TheMayor, Nov 12, 2024.
  1. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    539
    Pacific Northwest, USA
    Dave W
    On a somewhat related topic, Deoxit also works great to free-up sticky door lock mechanisms too.
    - Dave
    TheMayor likes this.
  2. TheMayor
    107,798
    Vegas baby
    UPDATE: I had 2 of these modules (3 total if you count the driver side that was working). The car came with a spare used module. Neither of these 2 for the passenger side worked.
    We used the DeoxIT D5 on both.
    One still had no function. The other came back to life. So, its worth a try. I saved about 3 grand.
  3. mixedgas
    mixedgas Formula Junior
    Apr 23, 2019
    293
    Ramona, CA
    Looking back at Post #4 it might be possible to resolder contacts inside the switch. I dont have any experience with these switches but might be worth a try considering the scarcity. Glad the deoxit worked out, as they say, "I put that stuff on everything" - switches, plugs / connections, grounding points, relay connections, etc.
  4. Skippr1999
    Skippr1999 F1 Rookie
    4,593
    My drivers side heater control with one red light lit, fails to power the motorized heater valve under the front hood. I’m not sure whether it’s the switch or the heater valve motor. I’m going out to my mechanics today with the car for new brake line installation and will investigate it with multimeter, etc.
  5. TheMayor
    107,798
    Vegas baby
    I would guess its the switch. I doubt there is feedback back to the switch about the actual position of the valve opening. To me the microswitches get dirty or worn. Unless its completely dead its probably not the circuit board inside the switch. Just guessing but this is 1980's tech stuff. Not very sophisticated.
  6. Skippr1999
    4,593
    Today we investigated the heater valve situation, Good News And Bad News.
    The Good News:
    The heater valve motor had very dirty electrical plug connections.
    Deoxide D5 cleaned it rightup. The motor immediately started working and the switch lights illuminated. Success !
    The Bad News:
    As soon as the valve opened up, the valve began to leak
    I began reading old threads here and found that the part is no longer available from Ferrari, but Maranello Concessionary has a alternative part for approx $500
    Another poster here on Ferrari chat mentioned that his heater valve only leaked when opened ALL the way up. If you stop before fully opened, the valve doesn’t leak. We pressurized the system To test and it turned out to be true. So, stop before all the top heater light is illuminated and you’re ok for now.
    I also played around with the switch and found the first heater light staying illuminated was sporadic. Mostly stays on, but sometimes goes out after using the heating system for a bit and then turning it all off. It usually lights back up though.
  7. Alden
    Alden F1 Rookie
    3,812
    Central Florida
    I live in Florida, and seldom if ever use the heater, so this was a solution to a slightly leaking valve on my 3.2 Mondial, probably would have been better to replace the valve but I just had a major service done and didn't want to tear into the engine compartment again, it works for me!
    Alden
  8. Rifledriver
    37,388
    4 Seasons is a major supplier of HVAC parts for cars. I just spent 3 or 4 minutes flipping through their heater valve selection and saw several that looked like they would be as easy to convert a 328 to as the one offered by Maranello Classics. They were under $50.
  9. Rifledriver
    37,388
    I dont think we need to resort to anything so limited in function. The world is full of cheap readily available heater valves that we can actually adjust
  10. Rifledriver
    37,388
    It would also be interesting to take a 328 valve apart and see if it can be rebuilt or resealed.
  11. Skippr1999
    4,593
    Here’s a video I found on possible repair solution
    What do you guys think ?
  12. Skippr1999
    4,593
    Someone bought the available heater valve from Eurospares and found it to not work like the oem version
  13. Rifledriver
    37,388
    I am sure it requires some level of conversion. But for $400 I can do a lot of fabrication to make a generic valve work.
    I still think the best plan is to see if the originals can be fixed
  14. Skippr1999
    4,593
    Did you watch the video I posted about inserting a small screw without opening the case ?
  15. Rifledriver
    37,388
    Yes. Not sure if it it representative of all but a good start.
    Skippr1999 likes this.
  16. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,362
    Sergio Tavares
    Yes, clean then fix the old, the seal may be a flat piece you can cut raw piece to make your new one
  17. carlrose
    carlrose Formula Junior
    Nov 25, 2003
    327
    To add a data point to this discussion: here is an image of a 328 heater valve from a dismantled UK car with part number (Bosch?) visible (0928400017); I presume the “549” is an inspection stamp
  18. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,780
    Argent/Brasil
    Guido
  19. Rifledriver
    37,388
    Good information. Surprised its Bosch.
    Sergio Tavares likes this.
  20. Sergio Tavares
    Nov 15, 2018
    1,362
    Sergio Tavares
  21. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    434
    Midlands,uk
    Paul
    The ac/ heater control centre console switches for sale on eBay at moment, haven’t seen any pop up for years in UK if anyone interested plus they other switches against seller
    https://www.ebay.co.uk/itm/257107238504
