Heater fan on 328? | FerrariChat
Heater fan on 328?
Discussion in '308/328' started by Fiat4Fun, May 11, 2016.
  1. Fiat4Fun
    Fiat4Fun Formula Junior
    Jul 1, 2008
    317
    Sunriver OR
    Bob
    Doing some spring clean up on my 328, and removed the lower spoiler to fix one of the attachment points. I see the fans for the heater with some foam filters. Can these be easily removed and cleaned? Didn't want to break anything, so I thought I would ask how best to remove the filter covers? Anything else I should I do while I am down in that area???
    Bob
  2. Rifledriver
    37,288
    They were designed to be removed and cleaned or replaced. As I recall the baskets that hold them in are screwed on. If the filters are in good condition they are made of a washable material.
  3. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    434
    Midlands,uk
    Paul
    Or you could just buy some suitable filter material and cut to fit, which I did recently.
    I used a cooker overhead filter, works fine
    Easy job cost £1 to do both fans, what that in dollars ---- cheap!
  4. Fiat4Fun
    Jul 1, 2008
    317
    Sunriver OR
    Bob
    Great, looks like the screws are in the center?
    Any other "projects" I should take on while in this area? Going to clean off the face of the AC condenser and check the thermostat probe for the AC, since I seem to have a issue with the AC temp setting and the dealer that checked my system did not find a leak or issues with the system. I know if I bypass the thermostat, it works just fine.
    Is there an area to grease the headlights or anything else "down under" to do, while I have the spoiler and covers off?
    Thanks again for the advice.
  5. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    I had a problem with the A/C thermostat which was caused by the capillary tube having got sliced inside the centre console.
    The tube ends near the expansion valve under all the black heat insulation gunge.
    I replaced the thermostat with an electronic type with a thermistor. There was a slight complication as the 328 wiring switches the ground side of the compressor not the positive side so I had to cut the PCB track in the thermostat to isolate the positive relay contact and connect the output wire to it.
