Heater Levers | FerrariChat
Heater Levers
Discussion in '308/328' started by JTranfield, Feb 13, 2008.
  1. JTranfield
    JTranfield Formula Junior
    Dec 29, 2003
    665
    NYC, London
    J Tranfield
    Does anyone know if a US 1977 GTB had either two defroster levers or two heater levers in the center? I have seen cars with both and am not sure.
  2. Steve Magnusson
    26,959
    I believe the stock set-up on all the carbed 308 is two air distribution levers and one temperature (hot water flow) control lever. If by "heater lever" you mean a temperature control lever, I don't see why you'd ever need more than one since there's only one cable-controlled temperature coolant valve. Since we know that these stock levers break often (and it's been 30 years ;)) probably a substitution if you've seen something different.
  3. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    There is 1 extra lever in the carb cars and that is for the choke. So it's left defroster , heater valve , right defroster and choke. 4 levers
  4. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Ditto what Steve says. My car's also a '77 carb.
  5. JTranfield
    Dec 29, 2003
    665
    NYC, London
    J Tranfield
    Thanks everyone, mine is missing the left defroster then.
  6. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,533
    Raleigh
    Kevin
    Well, I don't know I would call it the defroster lever. It is marked D E F but the function is more than that and quite sinister. The markings on the right side are 0 up-down and down. It has to be in the 0 position for A/C usage or if just "off". In the up-down position you get heat going up from the dash and down from the below dash vents. In the down only position you only get air from the vents below the dash. But, yes, four levers :):).
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,026
    Groton, MA
    Verell Boaen
    Vent lever is a more appropriate term.
    See the owner's manual, downloadable from the ferrari owner's site:
    www.ferrariowners.com
