Heater Relay Identification | FerrariChat
Discussion in 'Technical Q&A' started by moysiuan, Sep 1, 2021.
  1. moysiuan
    moysiuan F1 Rookie
    4,193
    Canada
    This is an Italmec heater system relay from my Mondial 3.2, also on the Testarossa's and some others.
    Can someone please confirm from the case diagram if this 5 pin relay is an always on or always off relay, or some other type? How would I describe this in order to find a suitable new one by Bosch or Hella, etc.
    Anyone know a Bosch part number this Italmec item crosses to?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,956
    Central NJ
    Dominick
    Normally open ..double output pins
    moysiuan and Qavion like this.
  3. Qavion
    Qavion F1 World Champ
    14,348
    Ian Riddell
    #3 Qavion, Sep 1, 2021
    You would have to know the current rating, too.
    Some relays have a diode or resistor across the coil. I don't know if these would be compatible in this case.
    This FChat thread mentions this Italmec relay with a Bosch equivalent:
    https://www.ferrarichat.com/forum/posts/144093013/
    But this is currently sold out on Amazon and eBay
    https://www.amazon.com.au/BOSCH-Current-Relay-Sportage-2058138/dp/B004Z0WHCA
    Narva has a 40 amp relay with a resistor across the coil:
    https://www.repco.com.au/en/globes-batteries-electrical/electrical-accessories/flashers-relays/narva-relay-12v-30amp-5pin-68024/p/A8468079
    Narva P/N 68024
    moysiuan and flash32 like this.
  4. moysiuan
    moysiuan F1 Rookie
    4,193
    Canada
    #5 moysiuan, Sep 1, 2021
  5. Steve Magnusson
    26,846
    #6 Steve Magnusson, Sep 1, 2021
    Those "maps" are the same relay logic:
    When the 85-86 coil is unenergized (which is how the maps are drawn) = the 30 terminal is not connected to anything, and the two 87 terminals are connected together.
    When the 85-86 coil is energized = the 30 terminal and both 87 terminals are all connected together.
    It should work OK as a replacement for that Italmec (as Ian noted the current rating may be slightly different, but it's a little too simplistic to put a single value as a current rating as the relay manufacturers usually rate life vs current and # of cycles, and there's no real standardization for these ratings -- so what one relay manufacturer calls a "30A relay" may not be exactly the same spec as another manufacturer's "30A relay").
    Qavion and moysiuan like this.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,956
    Central NJ
    Dominick
    the relay i showed you has 87 and 87 .. normally open .. i think the diagram (arm) doesn't make a difference
    Check amps though
    moysiuan likes this.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,956
    Central NJ
    Dominick
    we are writing and not seeing each others posts -- sorry for dup info
  8. moysiuan
    moysiuan F1 Rookie
    4,193
    Canada
    Thank you, now I understand the maps.
  9. moysiuan
    moysiuan F1 Rookie
    4,193
    Canada
    No marking on the Italmec indicating amps...not sure about the 160 number on the case after the 12V reference.
  10. Steve Magnusson
    26,846
    #11 Steve Magnusson, Sep 1, 2021
    I'm not either, but it could be the coil current in mA (when 12V is applied) -- just a guess. That Bosch 0332019151 is the later plastic case replacement for the stock Bosch 0332014113 metal case relay, and the Bosch 0332014113 is used on many F models for the HVAC blower motor so either the plastic ...151 or metal ...113 should be OK IMO.
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,956
    Central NJ
    Dominick
    #12 flash32, Sep 1, 2021
    the relays in the testarossa that have same internal config like the one you are referring to have a number of 332014113 ..but i am sure you already knew that - 30amps
    332014113
  12. afterburner
    afterburner F1 Rookie
    3,471
    Switzerland
    Urs STEMMLER
    #13 afterburner, Sep 2, 2021
    Make sure the pins are in the same location - there was a difference between the old Italian SIPEA relays and the new purple Bosch unit. I needed to swap round the connections in the socket for the Bosch to work.
    The new brown Bosch ones have the same pin attributions as the old SIPEA.
