Heater shut off valve? | FerrariChat
Discussion in '308/328' started by mixedgas, Nov 4, 2024.
  1. mixedgas
    mixedgas Formula Junior
    267
    Ramona, CA
    Hi there, I'm going through my heater cores and piping and wanted to ask if anyone has ever installed / considered installing a heater shut off valve? If so, where in they system would/did you install it? Goal is to eliminate coolant flow to the heater cores in summer months under the assumption that it would keep the cabin cooler in summer (no heat leakage around valves / ducting flaps etc). Thank you!
  2. mixedgas
    267
    Ramona, CA
    I was thinking of installing around this location (red dot in this figure). Also wondering if I should install two cut-off valves. Thanks for any thoughts! Image Unavailable, Please Login
  3. Rifledriver
    37,090
    I did it on my 328. Complete waste of time.
    mixedgas likes this.
  4. duners
    duners Karting
    Aug 16, 2022
    134
    Los Angeles
    Steven Carlson
    Seems like to truly isolate would require two valves. One at the heater pipe exit from motor and another at the y return from radiator.
    I thought of shutoff valves for mine and ended up working on ac system. I got the ac working and now it’s keeps me cool. Also, I don’t know how much the heater hose is contributing to the cabin heat compared to the radiator. Like previous poster mentioned - prob not much difference isolating heater hose.
  5. Alden
    Alden F1 Rookie
    3,601
    Central Florida
    #5 Alden, Nov 4, 2024
    I put one on my 88 3.2 Mondial at Tim Stanford's suggestion, when I was at his shop to pick up my car from major service he noticed that hot air was coming out of the vents before it got cool, he showed me a 308 he had in for service where they had put a cut-off valve, a simple ball valve in the left rear wheel arch, mine works great and since I live in Florida I've rarely used the heat, changed the temperature of my AC air from 49° to 39°. I got a 3/4-in ball valve from the hardware store and the bonus is that it has a bleed valve built into it and it's at the high point of my system.
    I know my heater valve was leaking and I probably should have just replaced that, but the service was done and I didn't want to leave the car, so I just installed the manual valve when I got home
    Alden
  6. Steve Magnusson
    26,785
    #6 Steve Magnusson, Nov 4, 2024
    Your model already has manual shutoff valves so, unless yours are broken (or mis-adjusted) and leaking flow, adding another one will make no difference. (Alden's situation is different -- he added a manual shutoff valve because his '88 electric shutoff valve is not working correctly.)
    Rifledriver and mixedgas like this.
  7. Rifledriver
    37,090
    Mine were not installed for the purpose of lowering interior temp but they dont. As Steve pointed out the factory installed valves. If they are working more is not better.
  8. Dr Tommy Cosgrove
    36,426
    Birmingham, AL
    Tommy
    Why did you put yours in?
  9. Rifledriver
    37,090
    A misguided desire to be able to isolate that section of the cooling system in the event of a leak.
  10. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    I wiped down all the beautiful valves and plating with wd40 to keep everything cleaned and preserved
  11. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,667
    Argent/Brasil
    Guido
    I did the same as Brain....the incoming flow cut. I see Brian did also the return flow cut. You have to do the return flow also otherwise warm water is still coming up to the heater cores.
