Heathrow shut after Boeing Dreamliner 787 fire | Page 2 | FerrariChat
Discussion in 'Aviation Chat' started by WilyB, Jul 12, 2013.
  1. targanero
    targanero Formula 3
    May 31, 2005
    1,661
    New York
    Simon
    If this latest fire is not battery-related, is that better or worse for boeing? Teething problems shouldn't include spontaneous fires from multiple sources. Boeing has been extremely lucky so far with this thing (in terms of no fires at altitude with passengers aboard)
  2. jcurry
    24,153
    In the past
    Jim
    If it was a crew error, then the image issue will be with Ethiopian, otherwise ....
  3. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,694
    Washington State
    Brian
    I missed it. Either way it's inaccurate, this specific bird has been airborne since mid-May.
  4. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    If a fire started at the APU battery location in the bottom RH side of the airplane you would see signs of that fire up the RH side of the A/P, NOT on the aft upper left hand side of the crown.
    To have a fire travel through the center of the A/P, through the floor system, galleys, lavs and ceiling panels to scorch the crown without leaving a sign anywhere else on the outside of the airplane is HIGHLY IMPROBABLE.
  5. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    You beat me to the punch. I'm no fire chief, but have had to diagnose and repair plenty of fire related incident's in automobiles, and I can tell you fire and heat are like a kid with sticky fingers, they leave evidence where ever they travel.
    No way IMHO could a fire propagate from the area below the galley where the battery in located to the roof without everything else in between becoming damaged
  6. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    I agree - but here is the deal: They got grounded for battery fires - supposedly fixed it - and yet now one of the "fixed" aircraft caught fire (on the ground, no less) for apparently NO GOOD REASON. The public will not care if it was the battery or the microwave ovens.
    This does a control-alt-C reset on the 787 problem record with both the authorities and the general public. On top of the completely unrelated 777 accident in San Francisco - bad news for Boeing. Bad news for the U.S. passenger jet industry.
  7. Tcar
    Tcar F1 Rookie
    Just heard on the news... radio.
    Heathrow just announced that the fire was NOT related to the battery.
    They declined at the moment to place blame for the fire, but not battery.
  8. tritone
    tritone F1 Veteran
    7,216
    On the Rock
    James
    You'll know when you read in the Business section above that people are shorting Boeing stock......
  9. GTHill
    GTHill F1 World Champ
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    Somebody that works for Airbus.
    GT
  10. FERRARI-TECH
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    The public wont know and wont care, because they wont know the difference between a 787 and a Cessna 172. All they care about is getting where they are going. I'm sure airbus will start a huge "don't fly Boeing" media campaign.
    Boeing should start a " if a French car isn't safe enough for American roads, why would you fly in their planes"
    If I recall a ton of 458's caught fire for the first year (design fault imho) that they where out but people still lining up to by them.
  11. TheMayor
    107,070
    Vegas baby
    True... but once they fixed the problem it never came back. If it did, I think the results would have been different.
    Boeing has an image problem with this plane. They need to get on it.
  12. Tcar
    Tcar F1 Rookie
    Neither of those things will happen.
    Airbus won't do that.
    Boeing won't do that.
    They both live in 'glass houses'. Neither company is without fault.
  13. WilyB
    WilyB F1 Rookie
    4,284
    AZ
  14. jcurry
    24,153
    In the past
    Jim
    #39 jcurry, Jul 18, 2013
    oops, the ELT has a lithium battery.
  15. RWatters
    RWatters Formula 3
    Feb 21, 2006
    1,075
    Kansas
  16. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,694
    Washington State
    Brian
    When a 787 catches fire you can't pull over and get out :D
  17. FERRARI-TECH
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    The 787 has been designed to only catch fire when its on the ramp and with no one in it.
    Clever folks are the Boeing boys and girls ;) ;) ;)
  18. KKSBA
    KKSBA F1 World Champ
    15,303
    SBarbara-La Jolla CA
    KKSBA
    I wonder if an aluminum skinned aircraft would have had holes burned through like that. I would imagine the conductivity of heat, and thus spreading the load, is better with metal.
  19. jcurry
    24,153
    In the past
    Jim
    Yes, plenty of evidence of similar damage from small localized fires on aluminum aircraft.
    Accident: Egyptair B772 at Cairo on Jul 29th 2011, cockpit fire
  20. Tcar
    Tcar F1 Rookie
    There aren't any holes burned through; all the pics show is charred paint on the 'roof'.
    Look at the first page of this thread.
    There may be CF damage (certainly there is) but there are not any holes.
  21. jcurry
    24,153
    In the past
    Jim
  22. Tcar
    Tcar F1 Rookie
    I was thinking the same thing... not needed any longer in commercial airliners?
    But, to be safe, wouldn't you need to remove it, not just disconnect it?
  23. jcurry
    24,153
    In the past
    Jim
    Remove the battery, which I believe it what they mean by making it inert.
  24. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
  25. KKSBA
    15,303
    KKSBA
    They're still needed in certain cases. These planes will be flying long overwater routes and there isn't radar coverage out there.
    Try to find a submerged airplane without an ELT in the middle of an Ocean. Sometimes, in the case of AF447, the ELT isn't even enough.
