Heating the Garage | Page 2 | FerrariChat
Heating the Garage
Discussion in 'Detailing & Showroom' started by dherman76, Oct 30, 2013.
  1. raider1968
    raider1968 F1 Rookie
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    #26 raider1968, Oct 31, 2013
  2. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Adding the tubing to do in floor radiant in an existing concrete slab is a pretty big job. I know people do it, but for a garage you'd probably go 12" spacing on the tubing and thats a lot of concrete cutting and mess.
    Radiant base board is minimally intrusive easy to retro fit and gives the same comfortable feel. It would be easy to run up into the room above too on a seperate zone.
    A small wall mounted "munchkin" type boiler is pretty efficient as well and can be hidden in an closet or shallow cabinet.
    Not sure you would get by on home owners insurance with an indoor wood burner in a garage (could be wrong). Electric is cheap to install, but can get a little pricey to run plus I feel it has a higher fire danger than forced air or hot water radiant
  3. YELO T
    YELO T Formula 3
    Jul 2, 2012
    1,193
    Long Island, NY
    Jonathan
    #28 YELO T, Nov 1, 2013
    Radiant heat tubing in the floor is good for new construction, but I would never specify it for an existing garage floor. Most slabs are 4" thick, and cutting into it, then patching, will weaken it, not to mention the mess and labor involved. I wouldn't use baseboard heaters either; they take up valuable floor space, plus dirt, leaves and crud builds up behind them.
    A compact wall or ceiling mounted unit with a blower (post #13) will efficiently warm up a 2 or 3 car garage in no time. Another solution is a low-profile european wall radiator (see pic). It's very efficient without taking up much space.
  4. ferrone
    ferrone Karting
    Aug 20, 2006
    146
    Ontario, Canada
    Don
    Radiant heat on the ceiling. did my garage and there is no smell of gas or fumes. Very cheap to use. put a thermometer In the garage and don't worry about it. The objects get heated not the air so it is more efficient when you open and close the garage doors
  5. 12097
    12097 Formula Junior
    Apr 4, 2007
    685
    Regina, Canada
    I have had radiant floor heat in one of our shops at work. It is probably the way to go on new construction. Once you heat the slab it stays warm for a long time. The temperature recovery time is quick as the heated slab in effect is the radiator. It is also warm to work on if you are doing maintenance and have to kneel or lay on the slab.
    I have had a natural gas fired tube type overhead radiant heat in the garage at home for about 25 years. It works very well and as was pointed out, heats the surface of anything beneath it, such as your car.
    This year however I am in the process of adding a four post lift to the garage. It is VERY IMPORTANT to maintain a minimum distance between the radiant heater and painted surfaces such as a car hood. If you do not, you will likely damage the paint finish on your car. (the intense heat will blister the finish). I think they recommend 6-8 feet.
    Due to the current placement of my lift, I am going to have to reposition my radiant heater or opt for a more conventional overhead heater mounted in the same area as my radiant heater.
    Hope the information helps.
  6. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    nice looking low profile radiator... are these avalible in the states? 110v or 220v?
  7. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,825
    wisconsin/chicago
    bo
    Dehumidifiers only work when its warm. As it gets cool, they stop working... Below 50 degrees, they do zilch.
    Bo
  8. YELO T
    YELO T Formula 3
    Jul 2, 2012
    1,193
    Long Island, NY
    Jonathan
    Try HudsonReed.com
  9. Dan Kyle
    Dan Kyle Formula 3
    Jul 9, 2013
    2,115
    Carmel Highlands
    Dan Kyle
    Good to know, Thanks.
    My garage is never below 50 degrees.
    Dan
  10. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    yelo
    many thanks i will check it out...
  11. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    I use a Dayton G73 mounted to the ceiling. It needs 220V but I had a panel and 220 installed for my shop tools anyway. It's a great little unit and heats my 3 car garage efficiently. The garage is attached, nothing above it, so I only run it on really cold nights or if I am working in the garage. It heats up pretty quickly and on the lowest setting it keeps things around 50, but can get it down right toasty. We are careful to open the door for a minimal amount of time when pulling in or out and it doors a great job of reheating quickly. I am very happy with it. I thought about natural gas, but didn't want to bother with having to vent it.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  12. dwhite
    dwhite F1 Rookie
    I kept my 1965 Jaguar XKE OTS in a storage unit in Long Island for 14 year. It was concours when I bought it and it still looked fantastic when I sold it recently. It was in a carcapsule and the car never, ever developed any rust or issues. My vote is definitly moisture vs cold/heat.
    I am now going to put my 308 in the car capsule.
  13. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,609
    NYC. / E. Hampton
    Michael
    #38 msdesignltd, Nov 5, 2013
    I like this 220 but I looked it up and found this
    Best Portable 220 volt electric Space Heater Choice? - The Garage Journal Board
    Heres a few more Electric options, only the 240 volts are worth looking at.
    http://www.air-n-water.com/electric-utility-heater.htm
  14. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
  15. George Vosburgh
    George Vosburgh F1 Rookie
    Thank you Spiro,
    I think this is what I need!
  16. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I have a Hot Dwag heater. Works great. I keep it around 50 all winter but if I work in the garage I take it to 65 in 3 minutes or so...
  17. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Radiant floor heat.
    set at 50F.
    no freezing and warm enough to work in the garage,
  18. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,766
    US of A
    Michael
    #43 Michael B, Nov 25, 2013
  19. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    George be sure that you have insulated overhead doors with good weather strip sealing all around.
    Sent from my Nexus 7 using Tapatalk
