Heatshields - replacement of... | FerrariChat
Discussion in '308/328' started by Andy 308GTB, Nov 6, 2016.
  1. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    #1 Andy 308GTB, Nov 6, 2016
    I suspect all my heatshields will need replacing but so far I have only pulled 2 (see photos). New ones can be purchased from the usual sources but they aren't cheap.
    Has anyone made their own?
    I had a quick poke around the interweb and there are some modern equivalents available but they look nothing like the original material
    i.e. http://www.demon-tweeks.co.uk/motorsport/heat-shielding-protection/nimbus-lite-heat-shield
    The originals appear to be 2 sheets of aluminium sandwiching some sort of material (asbestos?). I guess if I can find this filling material it shouldn't be too difficult to fold up the required shapes. Any ideas?
  2. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Don't use the old Asbestos material, but there are a number of modern heat insulating materials available today that will do the job and not be dangerous to your health. As you are in the UK, I am sure there are suppliers both there and near you in Europe. Good Luck Andy!
  3. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Here is my question. Are the heat shields around the exhaust necessary? Replacement exhaust manifolds don't have them...especially for the limited driving we do.
  4. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Good point Chaya! Maybe Jet Coating may be sufficient, in fact on another thread it was mentioned that the coating inside and out helped reduce the heat from the headers.
  5. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,083
    FRANCE
    Remember "Euro" cars (non-cat) and US cars (catalycists) have different manifolds, at lest OEM...
    Rgds
  6. BigTex
    79,386
    Houston, Texas
    Bubba
    The point of the heat shields varies...
    The header wraps can be deleted, but the ones shielding the alternator I would retain.
  7. Andy 308GTB
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    Thanks all.
    I'm guessing that the replacement manifolds will have the mounts for the heatshields - if they don't, this discussion is a bit arbitary...
    But I would definitely agree with the Big T that the alternator must have protection, even if nothing else does.
    I'm would still lean towards replacing the heatshieds, rather than coating or wrapping the manifolds in insulation. Mine are still good enough to be used as templates - the choice of 'filling' to be determined. But I won't be using asbestos - I think the court cases have all been settled, or the claimants long since passed away.
    Someone out there must have replaced the heatshields - did they simply fork out the money and buy the off the shelf replacements?
  8. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Just bought new from superformance, looks as if they have glassfibre insulation between the 2 sheets of aluminium.
  9. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    A more modern/high tech (and easier to make) solution might be to use a single sheet of Aluminium (for the look) with a sheet of Zircoflex stuck underneath it (on the hot side) .
    I stuck some to the underside of the rear luggage compartment a few years back - made a huge difference to keeping the heat from the exhaust out.
    ZircoFlex - zircotec
  10. Andy 308GTB
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    Thanks Iain - that's a neat solution, it even comes in a self adhesive form.
  11. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    #11 tinterow, Nov 7, 2016
    I was referring to the goofy soft aluminum thingys that surround the exhaust manifolds...This stuff! The ones that rattle! Can we take these off?
  12. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    #12 ferrariowner, Nov 7, 2016
    I have a nice US rear exhaust manifold if anyone is interested. Very low miles. It fits US 308 and 328's. Excellent condition. PM if your interested.
  13. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    Yep, its good stuff, been around for a while & well proven.
  14. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Try motorcycle parts/repairs shops and ask for exhaust packing/wadding.
  15. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Euro cars dont have that.
    But instead they have extra heat shields. In particular there is one which covers the starter motor. Without this, the bare exhaust is very close to it.
  16. nerofer
    Mar 26, 2011
    12,083
    FRANCE
    #16 nerofer, Nov 8, 2016
    To illustrate: I lifted this picture out of an E-Bay add from one of the main parts distributors (sorry, I don't remember which one); so sorry for posting it without crediting the one who took it, but this is the OEM euro REAR manifold for four valve engines, QV and 328, and the pic is interesting because you see the shields welded on the pipes; some are here for dampening vibrations.
    Note that it is reversed on the pic, because, contrary to US 328, on "Euro" cars (which are non cat) the rear manifold exits on the driver's side, then via a short intermediary pipe the shape of an elbow, into the silencer (muffler)
  17. Andy 308GTB
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    I don't think those are heat shields but as you say braces to stop vibration.
  18. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Thats right, SB 18-3 covers these, added from 328 no 68973.
    The Euro cars have other, separate heatshields.
  19. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    California SF bay area
    Paul
    Back to the original post and the link to the Nimbus Lite heat shield material.
    Although much different looking that the OEM material my guess is that it is more effective while being lighter. The complex dimples and corrugations not only provide rigidity but also dramatically increase the effective surface area for the purpose of absorption and dissipation of the heat. I think it's a product of more modern production processes available today as opposed to 35 years ago. I wouldn't mind getting a small piece to experiment with.
  20. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Wouldn't make sense if a metal heat shield was actually touching, would it?
  21. BigTex
    79,386
    Houston, Texas
    Bubba
    Well, Chaya "it's a part of the emissions" as it keeps our headers hot ahead of the thermo reactor muffler (or later CATs)..to lower the unburned CO.
    That said, the headers are prone to cracks, so I would argue that cracks tyou can see and repair are better than "cracks hidden".
    Euro cars do ont have the feature and work fine.
    Wear appropriate safety gear when you put the asbestos into the air....you could also ceramic coat them while they are loose!
