heavy clutch- any solution? | FerrariChat
Discussion in 'Technical Q&A' started by ricbowling, Oct 13, 2008.
  1. ricbowling
    ricbowling Karting
    Jan 21, 2008
    140
    Cascais
    Ricardo Almeida
    I just wandered if there is a way of making the ferrari 348 clutch lighter on the foot?
  2. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    A 12 month gym membership! :D:D
  3. F512M
    F512M Formula Junior
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    1. Bleed the clutch fluid. If that doesn't fix it, you probably need to replace the clutch. When mine was worn it was pretty stiff. After I replaced it the pedal feel was significantly lighter...
  4. Rifledriver
    37,121
    Buy a Miata.
  5. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    +100 on the clutch bleed. It made a big difference to my car. Bleed the brakes while you are at it - (same fluid)
  6. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    :D
  7. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    Those Miata clutches are pretty darn hard too, bucko...........:eek:
  8. ricbowling
    ricbowling Karting
    Jan 21, 2008
    140
    Cascais
    Ricardo Almeida
    which bolt do i need to undo to proceed to bleed the clutch ? what clutch liquid do you recommend?
  9. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Why would bleeding the clutch have anything to do with the effort required to operate the pedal?
    I think the effort has to do with the length of the pedal (mechanical advantage/leverage), the strength of the pedal return spring, the bore of the clutch master cylinder, and the strength of the springs on the pressure plate. And of course the effort would increase if the pedal is binding on its cross shaft, or if the release bearing is binding on its housing.
  10. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,812
    Cerritos, CA.
    I think the Civics are lighter:D
  11. F512M
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    +1... My Civic is super light.... :)
  12. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,842
    One other factor is the friction between the piston+seals and the bore of the slave and/or master cylinder -- if it's really gummy/funky, fresh fluid can help dissolve the deposits and decrease the drag there. But your point is well-taken -- many other (more likely) mechanical factors that can cause high pedal effort, and, if changing the fluid really helps, you'd have to consider yourself very lucky ;)
  13. PAP 348
    Dec 10, 2005
    100,220
    Pap
    I dont think I have ever come across that before. :D:D
    Yep yep. Thats it and nothing can be done about it. :):)
  14. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Here are some quick pics I took the other day when I bled my clutch and brakes in my 348. :):)
    The fluid has not been changed since last major in 2003. It wasnt full of crud in the master cylinder resivior (lucky), but the fluid was black and smelt nasty. :):)
    The clutch fluid shares the same fluid that is in the brake master cylinder. The clutch bleed nipple is on the bottom of the clutch pumpkin. :):)
  15. zippyslug31
    zippyslug31 Formula 3
    Sep 28, 2007
    2,075
    PDX
    Kevin M.
    +1 on the bleeding, or possibly needing a new clutch.
    Just had my clutch done (360) and one thing I was not prepared for was how light the peddle became. Nearly put my foot through the floor leaving the mechanic!
    And yes, the clutch and brakes were both fully bled and fluid replaced.
  16. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Drive a pre-1979 308 for a month and your 348 clutch will be light as a feather.
  17. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,047
    +1 ;)
  18. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Hehe! ;);)
  19. F512M
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    I'm not sure why bleeding made a difference but Speedysam bled his and it made a huge difference. I drove it before and told him that it was probably time for a new clutch. He went home, bought a speed bleeder, and got all of the old fluid out. The next time I drove it is was considerably lighter. I agree, I was scratching my head on that one, but seeing is believing... :) Unless he secretly replaced his clutch and did not tell anyone... LOL.... Sneaky....
  20. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Yeah, thats what REALLY happened! ;);)
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    I put a titlon carbon-carbon clutch in my 308. It's good for 800+ ft-lb torque and probably less pedal pressure than a civic. Really nice.
    some what related is my old chevy pickup. When the clutch would get worn in that it wouldn't slip but the pedal pressure got so higher I that I simply couldn't push the pedal. Replaced the clutch and it was back to factory easy.....I guess the linkage ratio gets screwed up as it wears.
  22. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    Altering your driving position can affect which leg muscle group predominate in pedal use and have a positive result too.
  23. F512M
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    Hey Pap!!! Your reservoir is on the wrong side of the car mate. That must be why bleeding didn't help your pedal any... :)
  24. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    In the southern hemisphere.
  25. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    And run around in a Diablo for a few weeks and you'll be butter clutching it for sure.
