HEEEELLLLLPPPPPP!!!!!!! | FerrariChat
Discussion in '458 Italia/488/F8' started by YoYo458, Feb 21, 2012.
  1. YoYo458
    YoYo458 Rookie
    Dec 16, 2010
    13
    Rabat, Morocco
    My Ferrari 458 has a very strong smell of gasoline. At first I thought it would go, but 700km and 4 weeks later it is still there and stronger than ever. My 458 has done about 4000km and I got it may 2011. The reason I am not rushing to my Ferrari dealer is for 2 reasons, one I don't know if it is dangerous to drive the car and it is about 6 hours away(it's in a diff. Country) please if anyone knows say it ASAP thanks :)
  2. atomicskiracer
    atomicskiracer Formula 3
    Mar 30, 2005
    1,736
    Ryan
    I think the only answer is to call your dealer....
    jm2 likes this.
  3. mathematics
    mathematics Formula Junior
    Aug 13, 2011
    338
    Toronto
    LeatherFoot
    +1
    Calling your dealer first is the best thing to do.
  4. hotsauce
    hotsauce Formula Junior
    Jan 23, 2011
    682
    around
    that's really interesting, gas is in the back and ventilation system is in the front (i think)
    Are there any variables that you can control that change the smell?
    IE turning on air conditioner, running at hot temperatures vs cold?
  5. Sedat
    Sedat Rookie
    Mar 7, 2011
    45
    Try lighting a match and seeing what happens ;)
    Mikael-F360 and Shadowfax like this.
  6. McRoswell
    McRoswell Formula Junior
    Jun 10, 2008
    335
    Roswell, GA
    Chris McAuliffe
    Call your dealer. The main fuel pump and sending unit is in back of your seat
  7. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    It is not normal. Definitely call your dealer and be prepared to trailor it there. Meanwhile there may be some other diagnostics you can note.
    Is there any evidence of a leak. (The bottom panels will prevent small leaks from spilling on to the floor, but look in the engine compartment with a flashlight.
    Will the odor appear if you only turn on the ignition. This will activate the pump and injectors but the flow will not be continuous.
  8. TheMayor
    106,192
    Vegas baby
    1) do not start or run the car
    2) call your dealer IMMEDIATELY
    Don't mess around with this. Is it dangerous? YES.
    Mikael-F360 and Ash Patel like this.
  9. YoYo458
    YoYo458 Rookie
    Dec 16, 2010
    13
    Rabat, Morocco
    To answer some of the questions, the smell only come when the car is on, it is stronger on the left side of the car, and the fuel pump is on the right. When I looked at it I couldn't see any trace of gas. What I am going to do is call the dealer and ask them to come. Thanks for all the care :)
  10. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    Good to remember that a gallon of gasoline has about the same explosive energy as about 50 sticks of dynamite, depending on the stick.
    GT2goneF likes this.
  11. ChuckStyl5
    ChuckStyl5 Karting
    Mar 28, 2004
    180
    The Armpit
    there is a fuel level sender on the left hand side right behind the driver seat
  12. YoYo458
    YoYo458 Rookie
    Dec 16, 2010
    13
    Rabat, Morocco
    What is the fuel level sender?
  13. Xeron
    Xeron Formula Junior
    Jan 25, 2010
    404
    Vegas
    Do not drive the car. I see you are in Morocco: Do not smoke near it. Get to your dealer.
  14. photonut
    photonut F1 Rookie
    4,080
    Michigan
    Joel
    not EVERYONE smokes in morocco! :D
    Ash Patel likes this.
  15. mathematics
    Aug 13, 2011
    338
    Toronto
    LeatherFoot
    Hahahahaha... you beat me to that.
    I was thinking exact same thing.
    Nice one mate!
    Need4Spd likes this.
  16. tazandjan
    39,181
    #16 tazandjan, Feb 25, 2012
    Near as I can tell, there are four fuel pumps in the 458, two mechanical ones driven by the cams for the direct injection, and two electric ones. They are all dangerous.
    Mechanical pumps #8 in first parts catalog drawing. Electric pumps #1 and #8 in the second parts catalog drawing from Ricambi's online parts catalogs.
    You 458 owners are fuel pump rich, to say the least. The electric pumps cannot generate the high pressures required for the direct injection, hence the mechanical, high pressure pumps shared with the California. The California does without the electric pumps, but then it does without dry sump lubrication, too.
  17. darth550
    Jul 14, 2003
    61,146
    In front of you
    BCHC
    Is Alan Funt going to post in this thread next?????
    Cigarzman likes this.
  18. YoYo458
    YoYo458 Rookie
    Dec 16, 2010
    13
    Rabat, Morocco
    Thanks a lot guys, you probably just saved me a 458 :) and it is rare to find someone who doesn't smoke ^^. And I am wondering, why would it be dangerous to smoke near it, I wouldn't but just wondering?
  19. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    The gas can ignite.
    Static electricity can also ignite.
  20. tazandjan
    39,181
    YY- Gasoline itself is not flammable, but the vapor is. So the smell you are getting is gasoline vapor, which can be ignited by any open flame source and sometimes even by an electric current or very small spark.
    When you get a gasoline fire, the vapor is burning, evaporating more gasoline, which burns. Next flammable rubber and other soft parts burn, and, when the temperature gets hot enough, the aluminum bodywork catches on fire. At that point, it is good to have a reputable insurance company, because she is gone.
    VAF84 likes this.
  21. OceanSide760
    OceanSide760 Karting
    Jul 8, 2009
    185
    do you smell it WHILE/AFTER stepping on the gas?
  22. Sultan_458
    Sultan_458 Karting
    59
    Uae
    Sultan
    Hi... I was searching for clear answer but unfortunately no one had the same issue... And I am sure your dealer never told you about what was the problem...
    Anyway I have the same issue and in the future if someone can read my answer and whoever have the same ferrari 458.. He need to check out the fuel filters cap... Normally its cracked by the time and because of the engine heat.... You may pay around £900 for both left and right fuel filter aside of labour charge.... And I believe you can smell the fuel from the left side of your car.
    I already change both sides even the other side is OK... As my friend said better to pay than lose the whole car.
    Hope this answer helpful to everyone have the same issue.
    Sent from my SM-N9500 using FerrariChat.com mobile app
    Regular Guy 01 likes this.
  23. cole328
    cole328 Formula Junior
    May 9, 2014
    882
    I love questions like this… If you owned a Honda accord, and you suddenly smelled gas every time you drove it, what would you do? You would call a dealer/ shop and have it repaired. No different with the Ferrari. It’s a car. Hope it turns out OK[emoji1303][emoji1303]
  24. Regular Guy 01
    Regular Guy 01 Formula Junior
    564
    Tacoma, WA
    Eugene Greer
    Thanks for sharing your knowledge with us fellow owners.
    I enjoy reading about others experiences and their problems with their cars.
    More than just hearing about them, I like to know why and what it took to fix them.
    I appreciate you sharing your information with us.
    Best wishes,
    Gene Greer
  25. Sultan_458
    Sultan_458 Karting
    59
    Uae
    Sultan
    You're welcome.
    This is a photo and you can see the amount of fuel coming out ones the car is on... For the first moment I thought its only seal problem but it was the complete fuel pump filter...
    This is the left side fuel pump filter. Image Unavailable, Please Login
