helicoiling for head studs | FerrariChat
Discussion in 'Technical Q&A' started by Squirrelmonkey, May 4, 2011.
  1. Squirrelmonkey
    Squirrelmonkey Karting
    Dec 27, 2010
    126
    Manitoba ,Canada
    Tom Thieme
    I heard someone say that one must drill and tap the engine block for helicoils and install them when replacing head studs..
    I have a 308 shop manual and could not find reference to this at all.
    In fact the manual implies that you can re-torque the studs more than once or twice for that matter without the need to replace them
    Comments?
    Tom
  2. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,806
    On the VW air-cooled engine design, I think that that's a common thing to do (especially if pumped up) -- but not on 308...
  3. tomoshea
    tomoshea Formula Junior
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    No need to replace the studs, even when upping compression, fairly bullet proof and over engineered.
    Only ever heard of very few snapping, usually corrosion is the issue.
  4. Squirrelmonkey
    Dec 27, 2010
    126
    Manitoba ,Canada
    Tom Thieme
    Thanks Guy's .. that what I like to hear.. already got my hands full as it is. no need for extra work.
    Tom
  5. PFSEX
    PFSEX Formula Junior
    Jun 30, 2006
    843
    Las Vegas
    John Ratto
    studs can pull out of block when torquing heads. It happens often with aluminum engines.
    How often have the heads been off? How many miles on engine? These are the factors to consider.
    There is another system that works much better than helicoils, but I cannot remember the name right now. Actually drill in a new threaded sleeve. Used on Porsche 911 motors.
  6. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    Timerserts. They have a kit for the 11mm studs used on Ferrari. But, unless the studs are broken or pulling out, there is no need to mess with them. Leave that sleeping dog alone.
  7. tempest411
    tempest411 Formula Junior
    Dec 3, 2010
    564
    I think it's Timesert, and another one named Keensert as well. I've used Keenserts at work, and I can attest to their very robust construction, and positive locking method.
  8. Peter
    Peter F1 Veteran Owner
    Dec 21, 2000
    6,440
    B.C., Canada
    The problem with using Helicoils/Timeserts/etc is that it's a very tedious operation and there'd always be a chance you could drill/tap off center, or at an angle when done by hand. I've installed Helicoils before (for the studs on the air-conditioning compressor) but in order to do it correctly, especially for a critical component like a head stud, you'd really need to do the drilling and tapping on a milling machine.
  9. TZ 750
    TZ 750 Formula Junior
    Jul 18, 2009
    912
    +10
    Especially the milling machine part.
    Studs must be VERY vertical ......
    Scott
  10. Squirrelmonkey
    Dec 27, 2010
    126
    Manitoba ,Canada
    Tom Thieme
    Thanks For your input folks,
    No question access to a milling macine is the best way to insure accuracy when drilling and or milling. However there is another solution for those that do this type of work often but cant justify the cost of machine tools like a mill and that is a Magnetic base drilling machine. http://www.toolbarn.com/champion-ac35.html
    These are compact tools that are very accurate where drilling operations are concerned
    You just need to magnetically attach the unit on a ferrous metal base This can be a steel plate,which in turn gets bolted to the top of the engine block. Locate the hole/broken stud to the drill chuck with a center drill or some other pointer. Hit the magnet and presto ! portable milling machine (sort of)..
    Work like a charm and not at all too expensive compared to when I used to import and sell these types of machines. Another major plus is you can mount these tools in any position
    The only limitation Is ones creative ability to mount or find a suitable location for a steel base plate if required.
    Regards,
    Tom
  11. yelcab
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    if you are fixing just one stud, there are the other 9 studs on the same plane to which you can mount a piece of magnetic base.
  12. DGS
    DGS Seven Time F1 World Champ Rossa Subscribed
    May 27, 2003
    71,911
    MidTN
    DGS
    No need for helicoils unless you've pulled the stud out of the block.
    In addition to drilling at the right angle and centerline, you also have to be precise with the drilling depth.
    Too deep, and there isn't enough stud above the head to thread the nuts onto.
    (I lost my GTV-6 mill to a shop that messed that up --- one of a series of blunders from a Fiatized Alfa dealership, as Alfa was dying in the US)
    That's one reason I always tell people to know where they can get an Italian car *competently* serviced *BEFORE* they go shopping for one.
