helmet | FerrariChat
helmet
Discussion in 'Tracking & Driver Education' started by 11506apollo, Jul 14, 2014.
  1. 11506apollo
    11506apollo F1 Rookie Silver Subscribed
    Oct 16, 2008
    2,699
    Tx Co Ca
    Can someone guide me to a website where I can purchase a safety helmet for the track? thanks.
  2. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,368
    Houston, Texas
    Bubba
    I'd use a Simpson.
    Factory store is in New Bransfels...but you really need to try them to determine the size.
    Maybe ProAm on Richmond and Greenridge is a dealer?
    Not sure, but I know they handle the clothing line....call them
  3. 11506apollo
    Oct 16, 2008
    2,699
    Tx Co Ca
    Thanks Bubba
  4. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    I wear a Simpson but I'd shop around for optimum fit, as Bell, Arai, Gforce and others make fine helmets. To me, a good fit and low mass are critical.
    And for a web site, try saferacer.com and helmetcity.com
  5. fluque
    fluque Formula 3
    Jul 30, 2004
    1,759
    Above 2240m
    Fernando
  6. Gran Drewismo
    Gran Drewismo F1 Rookie
    Jan 24, 2005
    3,778
    Idaho
    Andrew
  7. Canine64
    Canine64 Formula Junior
    Dec 18, 2005
    303
    Stilo carbon fiber FTW. You know, so you can kick some 911 "Azz"...
  8. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    Buying a helmet isn't easy. They're expensive and come in many styles, sizes, colors, and safety ratings. That means that a well stocked shop will have a HUGE investment in inventory. You may have to search to find such a shop.
    A good fit is VERY important, so buying one on-line is a bit risky. If you do, be SURE you can return your purchase if it doesn't fit properly.
    I think a good helmet is important and I always choke a bit when purchasing a new one because good helmets are expensive. But, I've also tested my motorcycle helmets a time or two against the pavement and my auto racing helmets a time or two against the roll bar without any apparent " dane-brammage", so I think it's money well spent.
  9. CornersWell
    CornersWell F1 Rookie
    Nov 24, 2004
    4,894
    You can also try discoveryparts.com and saferacer.com.
    CW
  10. V8ray
    V8ray Formula Junior
    Jun 18, 2013
    251
    Ray
    +1
    Beautiful helmet
  11. Heat Seeker WS6
    Heat Seeker WS6 Formula 3
    Nov 4, 2003
    1,704
    Milwaukee, WI
    John G
  12. GuyIncognito
    GuyIncognito Nine Time F1 World Champ Silver Subscribed
    Jun 30, 2007
    99,760
    great point, make sure whatever you buy is pre-drilled for whatever neck restraint you'll be using (I'd highly recommend HANS, but there are other good ones).
    pre-drilled or even pre-wired for headset/mic is nice as well. Stilo sells one ready to plug in to a radio IIRC.
  13. Rosso328
    Rosso328 F1 Veteran Owner Rossa Subscribed
    Dec 11, 2006
    7,344
    Central FL
    Paul
    As others have noted, fit is critical, and different models and brands fit a bit differently. a "Large" Bell will fit a bit different than a "Large" Stilo.
    I have gone through Saferacer.com in the past. They made it very easy for me to try a couple of different sizes, keep the one that fit and return the others no problem.
  14. speedsport
    speedsport Formula Junior
    Mar 14, 2013
    496
    IL/WI
    Michael
    There is no way you can purchase a proper fitting helmet your first time via the internet. Every manufacture's helmets fit differently. Some people's heads are Bell heads, some Simpson, some Arai, ect. Every brand fits different shaped heads differently. You need to find someone local who stocks different brands to try them for yourself. Keep in mind that most people who have never wore a helmet before always choose one that fits too loose because it's more comfortable.
    Forget what the "cool" helmet of the day is.....get one that fits right.
    For example, my head really only fits properly in a Bell. I can't even get the largest Stilo or Arai on.
  15. innerloop
    innerloop Formula Junior
    Jan 17, 2010
    260
    Houston Heights, TX
    This is the guy I used a couple of years ago.
    Custom Helmet Painting by Mike for your Ferrari, Viper, Porsche, BMW, Corvette, or other sports car or racing race car
    He has stock designs or he'll work with you to come up with your own design. Mine is supposed to be a combination of Senna and Colin Braun with some Ferrari red thrown in.
  16. Mozella
    Mar 24, 2013
    905
    Piemonte, Italia
    I used to use Simpson when I was auto racing in the U.S. and, like you, I could never find an Arai which would even come close to fitting. They were always too small and, in the U.S. at least, my racing friends all told me that people with large heads should forget Arai. They were wrong, as it turns out.
    Now I live in Italy and both my wife and I use Arai helmets for motorcycle riding. I learned that Arai has four different shell sizes and at least two different shell shapes (round head vs longer narrower face). They even have different shapes for Europe, Asia, and the Americas. I have a large head which is also quite oval, but I was able to find a good fitting Arai in Italy. Apparently, it all depends on the availability of different models at different shops in different countries.
    As I said before, a well stocked helmet shop will have a significant amount of money tied up in inventory because there are so many brands, styles, sizes, and options.
  17. Heat Seeker WS6
    Nov 4, 2003
    1,704
    Milwaukee, WI
    John G
    I'm lucky to work & live minutes from Pegasus Racing. Always gotten my stuff from there and when it came to the new helmet, it took some time tying on different sizes, brands & styles but the Bell I ended up with just feels right.
  18. GregD
    GregD Formula Junior
    Nov 3, 2003
    885
    California
    Greg
    +1.. A nice light weight helmet that properly fits your head.
    When you try them on, the light weight is very noticeable
    and more comfortable .. I think the extra cost is worth the
    Trade off on your neck...
  19. V8ray
    Jun 18, 2013
    251
    Ray
  20. sainthoo
    sainthoo Formula 3 Owner Rossa Subscribed
    Jan 20, 2007
    2,067
    Christian
    I'll add to the growing chorus- get the helmet that fits your head, forget what a buddy might have. I have exchanged helmets through saferacer as others mentioned, no problem.
    I have had a Bell, Sparco, and I just bought a Stilo which arrived today. The Stilo is definitely smaller than the others, but the built in radio, water and air is sure gonna be nice. I also like the built in noise suppression in the Stilo. Haven't had it on track to confirm the initial impression.
    If you are willing to spend the money, get carbon fiber, the light weight is really nice.
    If you have harnesses, get a Hans, otherwise look into some sort of restraint that works with your car (some attach to your torso, don't need the harness, I think).
  21. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    28,957
    socal
    I second helmetcity. Very good customer service. I like saferacer.com too and they give SCCA racers a discount on some stuff.
    *******Also, the snell rating changes in 2015 to SA2015 or SAH2015.
  22. ProCoach
    ProCoach F1 Veteran Owner
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Yeah, but the 2010 spec wasn't generally available until 2012!
  23. Schatten
    Schatten F1 World Champ Owner
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    Claudio, where in Texas are you? If you are in Austin, Winding Road Racing is off of 183 near Ohlen Rd. They carry many brands and have Stilos in stock. Otherwise, off to New Braunfels to visit the Simpson factory.
  24. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    This helmet just needs a webcam and GoPro option:
    [ame=http://www.youtube.com/watch?v=ZdcWd594lRw]SKULLY AR-1: Rebel Innovation - YouTube[/ame]
  25. Heat Seeker WS6
    Nov 4, 2003
    1,704
    Milwaukee, WI
    John G
    Whoah that's pretty slick! Would also be an expensive oopsey if dropped on accident.
