430 - HELP!! 05 430 Spider top won't come up | Page 2 | FerrariChat
430 HELP!! 05 430 Spider top won't come up
Discussion in '360/430' started by DrivnXcitment, Dec 16, 2021.
  1. DrivnXcitment
    DrivnXcitment Karting
    Apr 29, 2006
    226
    St. Augustine, FL
    Bryan
    Can anyone speculate, troubleshoot, or diagnose what could be the underlying condition to cause a top to do this? I’m all ears as to any ideas in case it happens again.
  2. DrivnXcitment
    Apr 29, 2006
    226
    St. Augustine, FL
    Bryan
    The fluid is full where it needs to be and appears to be in good condition. There are no leaks in the system either.
    Qavion likes this.
  3. Bob in Makiki
    Bob in Makiki Formula Junior
    May 30, 2017
    455
    Honolulu
    I had the flaps go out of sync and my right flap broke. My tech put in a new right flap and then sat and cycled the top for about an hour trying to find out what went wrong. He discovered one of the microswitches was failing intermittently. I’m now waiting for a replacement microswitch to arrive from Italy. There’s no reason to assume this is your problem, but I really hope this fixes mine.
    DrivnXcitment likes this.
  4. Metastable
    Metastable Formula Junior
    Maybe it’s this:
    There are three hidden bolts on each side. You cannot see them when the top is up or down. However they are visible while the top is operating…. Roughly 1/2 way during the up or down movement. Make sure the bolts are not loose!!! I do not have a picture handy, but it happened to my spider.
    Bob in Makiki likes this.
  5. Metastable
    #31 Metastable, Jan 6, 2022
    Ok maybe it is more than 3 hinge bolts….. check all of them. :D Maybe….. if the bolts are lose on one side it could cause the mechanism to tilt a little, especially if it was not operated on even ground……. A bit of a long shot. Picture of bolts below.
    Qavion likes this.
  6. DrivnXcitment
    Apr 29, 2006
    226
    St. Augustine, FL
    Bryan
    Are you talking the hinge bolts for the tonneau cover or something else? Just looking at the pics it looks like the tonneau, what the top stows under.
  7. Metastable
    Yes, the hinge of the painted cover the top stows under. When this happened, the little capote side covers were also not closing properly.
  8. Andviv
    Andviv Karting
    Jan 8, 2024
    57
    Reston, VA
    Andy Vv
    Too bad the links expired already.
    Would it be possible to get them again?
    thanks!
  9. Qavion
    Qavion F1 World Champ
    14,682
    Ian Riddell
    Here's the guide, Andy
    I can't remember which diagram I posted earlier, but the guide should help.
    Cheers
    Andviv likes this.
  10. Andviv
    Andviv Karting
    Jan 8, 2024
    57
    Reston, VA
    Andy Vv
    This is great. Thanks a lot!
    Qavion likes this.
  11. Rrariboy
    Rrariboy Rookie
    Oct 22, 2014
    5
    Los Angeles
    Filippo
    @Qavion COULD YOU SEND THESE LINKS AGAIN?
  12. Qavion
    14,682
    Ian Riddell
    I COULD!
    See post #35
    https://www.dropbox.com/t/sl4z0sE8UXQYq37O
