Help! '06 430: error code in 1 cylinder..Valve issue? | Page 3 | FerrariChat
Discussion in '360/430' started by pahig, Jun 19, 2014.
  1. ScuderiaWithStickPlease
    ScuderiaWithStickPlease F1 World Champ
    Dec 17, 2007
    10,263
    NY Metro
    Same piece of birch you use in the OR?
    :D
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,488
    Charleston, SC
    Curt
    A smooth clean piece. Held gently in the palm...
    If you're really good you can get AM channels. :)
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Owned by someone that bought it "used".
    Good luck.
  4. pahig
    pahig Karting
    Jan 2, 2009
    57
    st. louis, mo
    paul
    To clarify, I had issues with my previous 2 Ferraris as well, I just never requested FNA to help reimburse me for the expenses incurred with them.
    If it were an 8 year old car with 85,000 miles on it, I would not have questioned the repair cost. This is an 8 year old car....with less than 16,000 miles on it...which has not been tracked or abused. Of course it's out of warranty, so they're free to say Take A Hike. The question is, is that the right thing to do? This problem does not fall under "normal wear and tear". From everything I've learned, failing manifolds are a known problem, and ultimately these were diagnosed as "bad" by Continental. Those were still under warranty. There are a limited number of things which could have caused the valve problem, and right at the top of this list would have been a failing manifold. A spring or a guide was ruled out.
    So yeah, I don't think it's a crazy notion to think FNA might do more than cover 1/2 of the transport cost. How about ~all~ of the transport cost, because when I bought the car, part of what figured in the equation was that they had local authorized repair?
    What do I "expect"? I expect them to either not reply or tell me to go pound sand. But I do think there is something to the notion that if this car were owned by an FNA executive, the notion of connecting the manifolds to the valve issue wouldn't have been a pipe dream. I assume my note went to Italy, I will give thought to the London thing. Not that I give any of this much of a chance of changing anything.
  5. Rifledriver
    36,924
    The thing I was trying to get to before was, yes you had a valve problem. What kind of valve problem was it? To my knowledge you were not told. There are lots of valve problems for lots of reasons and yet no mention of what this was.
    Next you had a manifold problem. Manifold problems manifest themselves in many ways and evidently you do not know what that is in your case.
    You have no case unless a connection can be made and you have no information to make it.
    I suspect at this point that information is no longer available to you but you need it for any semblance of even suggesting causation.
    PS
    Don't write London. That will at some point become the address of Fiat Chrysler Auto but it is not now. They only just made the announcement.
