Help - 1987 Mondial 3.2 only fires on front bank of cylinders | FerrariChat
Discussion in 'Mondial' started by Lenvo65, Jun 11, 2007.
  1. Lenvo65
    Lenvo65 Formula Junior
    Apr 3, 2005
    293
    Bergen Cty NJ
    Only firing on the front bank (5-6-7-8) of the engine. A friend and I went over the car today - suspected it was one of the coil packs so we took them off - cleaned them up and all the connections and switched the packs front to back and vice versa. No chnage in the problem, rear bank still will not fire, however the rear coil pack (the one not firing) get hot as you run the car while the front one stays cool.
    I've read on some posts here that there is another circuit board and ECU in the rear trunk area some place, I've pulled back both sides of the rear panels inside and don't see anything that looks like it, where do I find it?
    Also is there a good and reasonable source to get a full workshop manual for this car?
    Any thoughts on where else to look are appreciated - was hoping to drive to work in the Ferrari for my birthday this Friday - looks like a no go.
  2. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    I'm sure you're going to get a ton of help here soon-------regardless, just go with the flow--------better the car need fixin' - den you!!!!!!!
    Cheers, Hank
  3. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Sounds like maybe one of the crank sensors. Do a search for them, many articles that explain them and related problems. (sometimes just a dirty or loose connection with them)
