I need help and YES I have used search-- no luck. I put my 81 308 GTSi NA version car in netural and took my shift-lever apart to change the shift-shaft bushing and just clean 26+ years of gunk outta the shift-lever mechanism. What a mess!!! All that is done. Now, I cannot get it together with the shifter working. I am sure I have knocked it into or outta some gear. Cannot seem to get it back together and functional. I thought the lever mechanism would "self-center" into a gear or neutural when you put it back together but no luck. It is only just a few parts.....sheeeeesh! Checked the Parts Manual and I have all the parts back in the right configuration. I tried moving the shift-shaft back and forth, and rotating side to side thru the gears looking for neutural or any other gear I could "see" and then reassemble. Again, no luck. Can anyone help me please!! I am stuck-- BIG TIME. Thanx in advance mwr4440
I think someone who has done it several times might be able to do it by feel. But, really, I think if you lost it in the gearbox the cover will have to come off and you will have to do a shift alignment from scratch as it were. You can do it yourself, but I understand the frustration as what you thought was a simple task just got 5 times more complicated. Seamus
It sounds like shifter lever (23) in the trans are no longer in alignment with the rocker arms (7). The best way to resolve this is to remove the bottom of the trans (after draining out the oil - be careful of the 3 sets of springs and balls (16,17,18) when you remove the case). Once inside, you will be able to see how the gear selection works. To do the job, it's best to have someone in the car holding the shifter while you make the adjustments on the outside shifter linkage. Then have that person go throught the gears as you watch the shifting take place in the trans. It will take a few adjustments to get it right. Even the slightest movement on the linkage adjustment will throw the gear selection off. It sounds more complicated that it really is, once you understand how the pieces work together. Good luck.
Try this: http://www.ferrarichat.com/forum/showthread.php?t=159281 I posted my amateur write-up on the procedure. I didn't get dinged on it (yet) .
Guys, You mean to tell me that by just removing my shift-lever for its 25-year cleaning, I have screwed up the transmission requiring me to open the #*^$(()@ thing up???? That is hard to believe. There has to be an easier way (other than paying Ferrari to do it). Doesn't there? Mark
I would think if someone could take a picture of all three selector shafts aligned in neutral you would have your problem solved. I had this problem once with an old Bronco and that is how we cured it. The forks where just out of place in reference to the neutral in the shift gate. Just my 2 cents.
Guys, Thanx. Keep the suggestions coming in. I DO appreciate them. There just has to be a way to "connect the dots" (read something like this: push the shift shaft all the forward and turn to the left; pull back using while depressing the clutch and at the third bump, turn the shaft left and there's neutral or second or whatever). There just has to be a way (I hope) w/o cracking the box (tranny). Im so pi$$ed off. Going on vacation to the Egyption Red Sea coast tomorrow and when I come back I'll start to tackle this SOB! Thanx again guys and all (serious) suggestions welcome. Mark
Mark, It's not that difficult to get into the gearbox. Just drain the gear oil, take the pan off. Have someone sit in the driver seat while you look at what happens as he selects gears using the lever. You should be able to figure it out that way. If you do this, be aware of the springs and balls for detents in the rods...just study the parts manual to see what I mean. Don't lose the springs and balls... -matt '85 euro 308
In my opinion, it is total BS that the sump needs to be removed to readjust shift linkage. Agree, it is a pain, but with someone that knows what the're doing in the car and someone who understands WHAT the're doing under the car, it can be sucessfully adjusted. I've done it twice in the past few years.
I cant be 100% sure, but i'm 99.99999% sure that taking the gear lever assembly apart will do NOTHING to the inside of the gearbox. The only place where the shaft is seperable is at the shift lever adjustment union in front of the gearbox. And because the gear lever housing bolts ridgidly to the tunnel with no adjustment, if you take it part and reassemble it properly, it should still work. That is, if it was properly in adjusment beforehand. The shifting has very low clearance specifications. Just having the lever a hair off side to side can screw it up. With the lever in second gear, the lever shouldnt be touching the gate on either side, or touching the end of the slot, nor generally in the other gears. So its highly possible that R&Ring the gearlever assembly could have "nudged" the adjustment off enough to screw you up. Under the car at the gear lever adjuster, loosen the adjustment nuts and place the gearbox into second gear and adjust the gear lever. I believe you will solve your problem there.
Agreed that it is entirely possible to adjust without removing the sump if you know what you're doing. If you've never looked inside the gearbox, taking the sump cover off will expose everything and make it quite easy and clear, but that does entail draining fluid and refilling, and likely replacement of that gasket, and being careful with balls and springs, etc. Try to do it without removing the cover, but if you give up, it's not a huge deal to take the sump cover off. -matt
I guess I could not imagine that the gear shift lever was moving around without connection, yet the shift forks were okay. I suppose that is possible, but having been through part of this myself as a newbie it seemed to me that when you have lost the gears it is because the shift forks are off in the weeds. Also, again speaking as a someone new, I simply cannot imagine getting the shift forks right in the gearbox without taking that cover off. When you have been there it is easy. If you have cannot picture what is happening on the other side of that sump cover you probably are not going to be successful doing it by feel or the orientation of the shift shaft. Seamus
Umm, Maybe... My guess is that what's happened is that while the shift lever was disconnected to replace the inner shift shaft bushing that the lever moved enough to drop the L end out from between the 3 shift forks. It's even possible that the lever was accidently rotated 180 degrees while the bushing is being installed. Once out from between the 3 shift forks, getting it back in between them is a 'feel' thing. Also, the if the old bushing was off-center as they often are, the new bushing may just be putting the lever off far enough so that the gate won't let things work(been there too). If I were there I probably could get it back aligned with your help, but I think Seamus is right, it really takes someone who can visualize what's happening inside the tranny based on what he's feeling. Good news is that it really isn't hard to sort out with the tranny sump cover off. My advise is to pull the tranny cover, or at least start the tranny draining BEFORE you go on vacation. This will let you work on it w/o getting a lot of oil in your eyes(been there).
If Verell is correct and the shaft rotated 90 degrees, the simple fix is to rotate it back. While I agree you can certainly see the mechanism with the sump cover off much more clearly, I also believe you can "feel" you way back home. The fact is, when the shift lever is in the fore and aft second and third gear longitudinal plane, the cross bolt that holds the shaft together in front of the gearbox is horizontal. Get that part back in its correct orientation, and you should be able to place the gearbox in various gears by pushing or pulling the shaft. Even if as Verell has suggested, a new bushing has thrown the adjustment off slightly, it should still be relatively close. Put the bolt horizontal, and push it aft, and it should be in second gear. Now do your shift lever adjustment and your problem should be behind you. Actually, you can most likely flip the shaft inside the gearbox 180 degrees from under the car after removing the crossbolt, and never have to monkey with the gearlever housing.
I've fixed this problem a few times before in the past without having to remove the pan.The first time I did it I didn't even know that it could be done with the pan off!The job is twice the pain if you do it alone.With someone in the car it's much easier to do
Mark, Give it the old poke and hope for a while. You very well might get it back into alignment. As said before, if you can visualize what's going on in the trans, you will be able to do this without opening it up. If not, drop the trans pan and then it will become very clear what needs to be done. Good luck.
I seem to recall that there was a thread on this with pictures of the pan removed showing what the rods should look like. I don't know where it is but I recall it showed the 90* shift rod end and how you need to move it to make it work again. Does anyone remember the thread????
I think you mean this thread: http://www.ferrarichat.com/forum/showthread.php?t=24678 The pix are in it, but you sort of have to have an idea what you're looking at to interpret them. Maybe taking a good look at the FPC at the same time as the pix will let you figure it out.
Yep , that's the one. Nice find Verell. I guess working with the info on a few of these threads may give you an idea on how to line up the rod without removing the cover. But incase you need to remove the cover it looks like a simple job but just need to make sure you catch the springs and balls. Thanks
OP, Read Paul's last 2 posts he is right and right. You'll learn more Verell's way... then you will know Paul was right.
I've done the adjustment a couple of times too, and still cannot imagine being able to do it with the sump cover on. It is just too precise. Only after years of practice could this be done accurately without seeing it. JMHO. Taking that cover off is simple (much easier than the crankcase sump!), and then you can get it perfect. Two people make it MUCH easier. Sounds to me like the new bushing simply put it a little out of whack.
I do not claim to have years of experience with Ferrari or in particular the 308 gear lever adjustment, nor would I claim to be any smarter than anyone else. But I will admit I do get frustrated that I always seem to be alone fixing my own stuff after fixing everyone elses, and over the years my crabby attitude has forced me to find ways to work alone and solve problems by myself. The second 308 I bought had the gearlever go stupid about a mile from home. I cant recall now exactly, but it seems I had only either first and reverse, or second and reverse, and everything else was missing. So I about faced and I headed back to the garage and put her up and stands (again). I pried the sump cover off (and lost all the $$$ oil I put in a few days before) to locate the problem. I assumed a fork or lever had come loose and slipped, but no, everything was tight. What I believe happens is the shift pawl (the finger that works the other three fingers) moves out of its groove and goes out into empty space if the lever isnt adjusted correctly. So I readjusted the lever, spent better than an hour laying on my back carefully scraping glued on paper gasket off the gearbox and cover, and angry I didnt find anything wrong inside. I put it back together with a new gasket, filled it with more $$$ oil, and took it out for a ride. Two days later it did it again. Back up on stands (again). But I was NOT pulling that $#*&@% cover off this time and wasting more $$$ oil. So this time I undone the adjuster and attempted to fix it from there. I loosened up the jam nuts on the adjuster and then pulled out the cross bolt from the linkage rod to disconnect the linkage. Then I began manipulating the shifting inside the gearbox from the front, turning and wiggling, pushing and pulling on the shift rod, until I could "feel" the pawl moving between the others. Knowing that 2nd and 3rd are in the middle plane, knowing the cross bolt HAS to be horizontal, I started shifting it manually from the front of the gearbox into and out of gear. When I was confident I had the gearbox in third, I went up and put the the shift lever in third gear position and went to reconnect the linkage and put the cross bolt back in. First I adjusted the fore and aft. I adjusted the length of the rod to bring the lever so it just wouldnt touch the end of the 3rd gear slot, then shoved the lever forward into second. (note, I didnt want to move the lever out of the fore/aft 2-3 gear plane as the adjuster was still loose) Then I readjusted the length to get the lever equadistant fore and aft. Once I had that figured out, I securely tightened one jam nut on the adjuster, and started to find the lateral (side to side) adjustment. Because the lever moves so very little within the gate slots, I dont believe the amount of movement there is very critical. But if you have the gearbox in 2nd, and you wiggle the shift shaft going into the gearbox while its disconnected, it will rotate quite a ways left or right. Common sense says it MUST be centered. So, in 2nd, and with the lever in second gear, but with the adjuster still loose with only one jam nut jammed, so that it will swivel left and right freely, I centered the shift shaft in the gearbox, and locked down the other jam nut semi snug. Then I carefully shifted the lever into each gear, noting how deep it went in the grooves, or how tight against the sides of the gate it was in any particular gear. IMO it should be in balance all around. If its too tight side to side against any slot, you could be misaligned within the gearbox. If it bottoms against any groove, the length is out of adjustment, and in extreme cases it may not be fully engaged into that particular gear which could potentially cause syncro damage or popping out of gear under high power loads. Verell and many others over the years have tried to find the reason some cars have poor cold second gear shifting, while other cars do not. Verell has suggested shift adjustment as a possibilty, and I agree that that is one possibility. But another is that I feel the gearbox linkage was so tight and heavy when new, simular to trying to work the action on a brand new Winchester model 94 rifle, for example, that it may take these cars years to wear in well and shift nice. And with the linkage being that tight and stiff, it may make some paticular cars very sensitive to shift lever adjustments.
I posted something similar way back when we had ferrarilist! It will fall on deaf ears. But you are totally on target. This is how you adjust the shifters. I've had 3 ferraris and all mine shifted fine cold in second gear! By the way I have a Model 94 too. Good job Paul you are the hero of this thread. I hope people will listen to you.
Well Guys, There are very few things on earth that can relieve the pressures on mind, body and soul like the Red Sea. My blood pressure, usually triple digits over triple digits with a resting heart rate to match, finally got down to the very high side of normal (with meds and MD supervision). I L O V E that place. Doing the work 5 civilian upper mid-level managers simultaneously for four of the past five years while back in uniform darn near KILLED me. That plus lots of life changes coming up (hanging up my uniform and moving to a new job and new military installation in Bavaria in my civilian capacity caused a tremendous amount of angst over the past few years. Ah, the Sinai, the Red Sea, sunset, a Stella Beer....... true bliss. What the Red Sea can give in a week, a "broken Ferrari" can take away in .... well ..... seconds. Dam*!!!!! Pegging the meter again.... Anyway. I have memorized my 81-82 GTSi Parts Manual (TAV 26 - Inside Gearbox Cntls) and went outside to fix Carmelita. It seems to be pretty simple after examining it and the pics from the other threads (THANX Guys!!). As a old semipro magician and champion rifle shooter I think I have a pretty good "feel" for things. Also being legally half to 3/4's deaf, I am a visual kinda guy and always was so, so "seeing in my mind's eye" what is going on as I manipulate the shift shaft (in and out, rotating right and left) as it relates to movements in the tranny box should not be in the "too hard" category. However, what I feel and what I "see" don't quite match. Could use some more input before I throw in the towel and crack the tranny as has been suggested. I have so little room in my garage (no heat, no light (use candles and flashlights) and less than 18 inches clearance around the entire car) to work that cracking the box it is a MAJOR undertaking. But hey, it IS my dream garage as it contains my FERRARI!!!!! Let me give you a better understanding of what I observe, "see" and feel. Some may be a recap from posts above. I MAY say something here that may just trip that proverbial trigger in someone's mind and we have a "Eureka" moment. General Setting: The interior is completely out. No seats or center tunnel. All movements described will be as if I was sitting in the driver's seat. Depressing the clutch does NOTHING by way of changing things vs. moving the shift shaft w/o depressing the clutch. For all intents and purposes the clutch has just vanished. 1.) Placed the car in neutral (should have been 2nd gear in retrospect), and removed the shift-lever for cleaning and forward shaft bushing (made of delrin) replacement. The new bushing was VERY tight to get in and the connecting bolt thru the bushing had to be hammered into place. The bushing hole was WAY too small. I rotated the shaft clockwise (as if in the driver's seat) about 90* for a better angle, placed a block of wood under it for support, and gently but firmly tack-hammered the bolt thru the new bushing and into place. I placed on the retaining nut and that is when the "fun" started. 2) Manipulating the shaft with or without the clutch depressed and replacing the shift lever will only allow me to find what appears to be 3rd gear. NO Movement of the lever or shaft is possible when the lever is replaced and tightened down. This probably ain't really 3rd gear. No other "gears, real or imaginary" are possible to find with or without the lever in any position or by manipulating the shaft and then replacing the lever-- not even neutral. 3) The shift shaft has about 6+ inches of total fore and aft travel; well out of its operating parameters. This total range of motion is accomplished by the following movements: a) Pulling the shaft all the way forward and rotating counter clockwise (CCW) slightly I find it locks. No movement possible. Rotating clockwise (CW) slightly and moving it aft, it finds a detent and locks again. Pulling slightly forward and rotating CW again releases this detent and allows movement aft to what appears to be neutral. It is not neutral, but "3rd gear" (see #2 above) when the shift lever is replaced. Here is also where I have the most CCW travel and still it is not much but I believe it is in the operational parameter range. Aft of this I have NO CCW rotational movement possible. b) I cannot continue rearward travel of the shift shaft w/o +/- 90* of CW rotation and then it travels the rest of the way hitting and glancing off of several (2) objects (TAV 26, Part 7's???? This I doubt, as that feeling should be rotational in nature) on the way back. At the end of rearward travel I can turn the shift CCW back to where the shift shaft joining bolt is horizontal. 4) Here is what all this is telling me, I think. a) Possibly that, TAV 26, Part 23, Lever, is (near?) hopelessly disconnected from the three Part 7's, Rocker Arms. The Rocker Arms are in misalignment with each other to a degree that "fishing" may not rectify (at least not easily, as verified(?) by me). b) Possibly that I rotated the center piece of the shift shaft so that what I observe and what I "see" and feel are in conflict. Meaning that when I hammered in the forward bushing bolt (TAV 27, Part 32) I rotated the center portion of the shift shaft (Part 29) so I no longer have the integrity of the system I had before. I am therefore "blind." c) I broke something. This I find hard to believe but perhaps when hammering with a lousy few oz. tack-hammer, I have broken the "unbreakable" before........... Guys, hope this makes sense and as always, your thoughts are greatly appreciated. Mark P.S. Since I cannot seem to positively ID them in the manual, what are the parts numbers (shift shaft seals) I should replace, since I will likely do a "while youre in there....." Funny, that must be the most lucrative phrase for vendors in the entire Ferrari lexicon.
