HELP 328 IS MISFIRING | FerrariChat
Discussion in 'Technical Q&A' started by rezone, Jun 27, 2006.
  1. rezone
    rezone Rookie
    Dec 25, 2005
    24
    The last couple time I went for a drive my 328 drove fine for a length of time then suddenly lost power and seem to be misfiring until I got it home and stopped the engine. No warning lights are coming on.
    any good thoughts of what this might be. Car has been service regularly. Read in manual that the brain of the fuel injection is called the ( ECU ) or the injection electronic control unit. Maybe it goes bad while driving and sends to rich of a fuel/air mixture. All help appreciated, Cliff
  2. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Could be anything, but fuel starvation was my first impression from the description. How's the fuel filter? If that's not it, then you need to do the normal diagnostic by checking the big 3: Are you getting fuel? (Fuel pump, clogged line, all that fancy FI stuff you guys have; accumulators and such). Are you getting spark? Is the timing correct?
    If you have fuel, spark and timing, the car will run.
    Ken
  3. rezone
    rezone Rookie
    Dec 25, 2005
    24
    thanks Ken, changing spark plugs tomorrow, maybe fuel filter if I can find one locally. No equipment to run diagnostics at home. Maybe fuel pump is starting to go, car has 56k miles on it so might be time to replace it. not sure the ave life of a 328 fuel pump? Thanks again Cliff
  4. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    If it's ignition related, it's more likely to be the spark plug extenders. When you get them ouot, look closely for burn holes are the start of holes near where the electrode connector is. Your description does not really sound like this problem, but worth a look. If you have tried to wash your motor recently, then extender failure is very likely.
    Dave
  5. Dan
    Dan Rookie
    May 26, 2006
    4
    Park Ridge-Ill
    Dan
    I think you have a bad O2 sensor---Disconnect the single green wire to the O2 sensor and electrical tape the contact--You dont want this to touch bare metal and go to ground while you are testing to see if thats the problem---The car will run in default mode with the o2 disconnected--Run the car up to temp and see if the missing still occurs---If it doesnt miss , replace the O2 sensor---
    The wire connection for the O2 sensor is near the fuel injection intake --You might have to remove the air cleaner and metal shroud to get to it--Dan
  6. santacruzn
    santacruzn Rookie
    Nov 10, 2003
    44
    Santa Cruz, CA
    Bill Grace
    Hi,
    I have a similar experience that was resolved with Hardtops advice. So check your plug wires for resistance through the extender.
    ZGood luck!
    Bill
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    The 3x8 fuel filter is readily available from AutoZone, Pep Boys, etc. You need the BOSCH P/N for them to cross reference. Brand doesn't matter as they're all made by the same company in Israel!
    Don't remember p/n off-hand, but a search of the archives will turn it up as I've posted it half a dozen times. I know it's in the Old FerrariChat archives several times.
    BTW, the 328 uses a mechanical injection system. You might try running a bottle of Techron concentrate into half-empty gas tanks, or 2 bottles into full tanks. Don't add gas until you've driven most of it out as you'll dilute the mix. It'll clean your injectors & the fuel system in general, including getting any accumulated moisture out.
  8. f355spider
    f355spider F1 World Champ
    18,045
    I would agree, if you suspect ignition, check the extenders first...also check the condition of the wires. Not a bad idea to pull the distributor caps off and inspect the condition, and also the rotors. Go ahead and remove the wires from the caps, cut 1 or 2 cm of wire off, and reinstall the nut back down on them. Gives you a nice fresh connection to the cap.
  9. rezone
    rezone Rookie
    Dec 25, 2005
    24
    My latest suspicion is a coil going bad as the car heats up the coil to the front bank of cylinders it stops firing those 4 cylinders. Should she go to the shop for diagnosis and repair or should I change the coil, distributor cap and rotor for the front bank? Do not want to replace a bunch of unnecessary stuff. Thanks alot
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    While coils can fail, it's pretty rare. A test would be to switch the coils. Do a complete switch, ALL wires from one coil to the other. If it really is the coil, the problem will move to the other bank.
    What will give similar symptoms to a badthe front bank timing sensor. If the sensor has a bad connection, or is failing, the bank won't get ignition. ie: w/o pulses from the sensor, the ECU won't fire the coil.
    Has your car had the ground strap added for the ECUs? If not, now is the time to add it. A quick search of the archives will give the procedure.
  11. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    on the 328, you can test the ignition modules by just swapping the plugs between the two modules. You don't need to touch the rest of the wires.
    If you want to swap the coils themselves, though, you must move the coil wires and at least the plugs with the red and red/white wires. Moving the yellow wires is optional, but it does give more information since those wires are independent back to a connector in the passenger footwell.
    If you yank off all the wires and forget which goes where, the plug with the red and white wires belongs to the 5-8 bank. The plug with two red wires is the 1-4 bank.
    I dunno if it matters on the marelli coils, but the yellow wires should go into the terminals marked 15 on the bottom of the coil frame.
