HELP, 328 WON'T START | FerrariChat
Discussion in 'Technical Q&A' started by Rosso Corsa, Jul 10, 2008.
  1. Rosso Corsa
    Rosso Corsa Karting
    Jan 24, 2006
    101
    No.Fork Long Island
    Lee
    Not started for 3 weeks (business trip) in garage, connected to a battery tender, car turn but will not start, not smell of fuel or others, just will not fire-up. PLEASE HELP.
    Great day and love to take her out for a spin!!!!
    Thanks......................
  2. desire308
    desire308 Formula 3
    Oct 19, 2007
    1,433
    Florida
    Peter W
    Go to the basics, check all grounds and fuses ;)
  3. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Also, charge/test the battery. If it's not in optimum condition, a maintainer wont help it.
  4. DGS
    DGS Seven Time F1 World Champ
    73,932
    MidTN
    DGS
    #4 DGS, Jul 11, 2008
    Air, fuel, and spark.
    Check that the fuel pump runs (push down on the plate, or remove the blue connector. --- But don't run the pump long without the car running, or you'll flood the intakes and it won't start until the fuel evaporates -- several days.
    You can use a spark tester, an inductive timing light, or just hang a spark plug with the wire on and the base grounded to the block to see if it sparks. (Taking due precautions with high voltage, of course. Don't rely on the plug wire insulation -- you can get zapped right through the insulation, if you're holding the wire.)
    Check that the throttle cable pushes the butterfly.
    If you have fuel, spark, and air, it should start.
  5. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
