Help! 348 front brake caliper locked partially on. Where can I get a rebuilt one? | FerrariChat
Discussion in '348/355' started by tbsb9595, Jun 4, 2007.
  1. tbsb9595
    tbsb9595 Guest
    Sep 19, 2006
    105
    Largo, FL
    Tom Sweet
    My right front brake is partially locked on causing the brake to over heat badly. I assume that will need to replace the caliper, so where can I get a rebuilt caliper? TIA
  2. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    Tom,
    If it were my car I'd have the current caliper carefully checked out and a definite problem found before replacing it. My concern is that the caliper may be "locked" because of another problem in the system.
    Brakes are one area where there are no second chances....
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I had a sticking caliper on the left rear wheel on my 348 causing the wheel to get very hot. It turned out that the pads were worn very thin and had become very slightly "cocked" in the caliper, so that they would not release. New pads fixed it 100%.
    It's also quite possible that the flexible "rubber" hose going to your caliper has broken down internally, and it's holding pressure when the pedal is released. The hose can look totally fine on the outside and be plugged on the inside. To me, that's probably more likely than a problem with the caliper itself.
    As Lusso said, you want to be sure what's wrong before you condemn the caliper.
  4. Harold
    Harold F1 Rookie
    Jun 19, 2004
    3,305
    Singapore/Australia
    As mentioned earlier, there are no second chances with brakes. Had some issues with my front right calliper sometime back that could not be resolved regardless of countless tries at identifying the problem. In the end we went the expensive route of changing the callipers and lines and all was well.... just wished there had been a cheaper fix, but for safety reasons this is something I wont save on.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Good man!
  6. zakeen
    zakeen Formula Junior
    Aug 29, 2004
    989
    Czech Republic
    Good luck sorting your problem. If you do need a new brake, PM me. Ive got a pair sitting doing nothing at the moment. Ive upgraded my brakes a while ago.
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Try opening the bleeder on that caliper. If this releases the brake, then it's the hose.
    This is a very common problem especially with older cars and not unheard of on 348's.
  8. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    +1
    Double check the hoses before jumping to the conclusion that it is the caliper. The calliper may show the effect but may not be the cause...
