Help. 348 overheating fans not going on. Help help help | FerrariChat
Discussion in '348/355' started by tommygunct, May 9, 2016.
  1. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    I had her out one day and she overheated no fans.
    I changed the thermostat no change bled it a 100 times
    Same thing. Changed the 2 sensors under the plenum and the radiator fan sensor bled and bled same thing
    Jumped the fans they both work changed the coolant cap and switched around or changed all relays. Checked all fuses. And no change. Thermostat opens at around 195 degrees going by guage on the dash I think that's to hot ??
    fans still don't go on. The passenger side radiator is alot hotter on the bottom half than on top near the fan switch. Could it be the radiator ?? Or dammed air?? I was told the drivers side fan should go on when the ac is on cold and high it don't
    Water pump seems working as water comes out of bleeders at a good stream and no squeel ing
    I hear a loud click when I hit the ac but can't tell from where. Near the back of engine as best I can guess but not the fans they spin fine and do go on but only when temp Guage shows like 250 deg if I run it with the coolant tank cap off as soon as the thermostat opens it gushes out. I had the radiators flushed and was told they flowed fine.
    I don't just wanna rig a toggle swith to the fan sensor obviously there is an issue and would rather fix it.
    Jumped the oil fan swith and the fans fine. Omg I wanna jump off a bridge. I would love to be able to just drop it off and get it back all done but like every other working stiff big repair bills hurt. Big time please help me my fellow fcar junkies tommy gun 203 488 8550 if it's easier to tell me if you have a couple pearls of wisdom
  2. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    Oh one more thing. It never used to go over like 200 before. And the fans always went on before 195.
  3. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
    edit: saw you checked relays
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Is your coolant level at the right amount. What seems unusual to me is that the bottom and top are not close to the same temp.
    Maybe you have an airbubble keeping the fluid high in the overflow even though its low on coolant.
    If you can when cold squeeze all hoses and check if coolant goes up in overflow this should kinda confirm no air bubbles.
    You can also take out one sensor and put it in boiling water and see if the resistance changes. This should tell you if the sensor is working.
    I have a 355 so not as familiar with the 348.
    I would also check the coolant temp with a temp gun as the engine warms up with cap off it should read about same as gauge. You only need to confirm at like 130 or 140 degrees. If its the same then you know the gauge is acccurate.
  5. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Does anyone have a decoder ring? ;)
    Almost sounds like a broken water pump impeller *if* I'm reading the post correctly.
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    If all those chck out i agree with above post likely the water pump is not working properly.
  7. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    I'm gonna try the squeeze the hoses thing and see but I think I did it's been a blur after the last 2 weeks. I tried high level in tank. And lower to see if it was that. Left bleeders opened all night and bled them with heat on car not running. And with motor running. With the ac on
    Warm. Hot. And cold. Put air pressure pump on cap. No leak down. No leaks. And no smoke or steam from exhaust or milky oil in the oil tank. How in the hell ban I test the water pump.
  8. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    Im ready to pull out the thermostat and run none. I got no problem with long warm ups
  9. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    But it still don't settle the fan thing I guess
  10. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Your sure your temp gauge is working right? Try a temp gun.
    I do know one thing ..keep letting her get up to 250 deg and your going to have more problems than your fans coming on late.
  11. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    The "click" you hear when you push the A/C button is normal. That's the sound of the magnetic clutch at the front of the A/C compressor (lower right front of engine) engaging like it's supposed to.
    Would disconnecting a coolant hose after starting the car maybe give an indication of coolant flow rate? Of course you won't have a normal Ferrari to determine what it should be, but I would think it should show a pretty heafty stream gushing out. Do it with the thermostat removed so you can do it on a cold car. Much safer for you.
  12. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Another thing you could try doing it you got a temp gun, is to get the engine up to running temp, get a baseline reading for one of the hoses, then bypass the fan switches so that you manually get them to run, and watch the temp gun and see if the temp falls. If your water pump is iffy, there probably won't be much change.
  13. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    First thing to verify is that temperature guage, second is the resistance of the sensor at 100C (or there about). If the guage is wrong, you may be chasing ghosts.
    Sent from my SM-G920P using Tapatalk
  14. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    This is good advise and where I would start. Given that you say the fan doesn't come on when the AC is started I would think it electrical in nature because you are correct that fan should start. Heck, it could be something as simple as a bad ground and you are not actually overheating. It's a pain to track these type of gremlins, keep us posted. Hang in there.
  15. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    Are you bleeding the cooling system at the bleeders on the transfer pipe on the firewall ?
  16. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    Yes bled them 10000 times. It's gotta an electric proble . I had enuf. I gotta admit defeat I gotta bring it to someone. Im done.
  17. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    Look I'm so disgusted I can't even put a coherent sentence together. I'm starting to get chest pains
    I should have bought a god dammed tesla for Christ sake
  18. m.stojanovic
    m.stojanovic F1 Rookie
    3,289
    Serbia - Niš
    Miroljub Stojanovic
    On my '91 348, the AC condenser is at the front (in front of the right wheel) with its own fan so the engine cooling fans operation is not linked to the AC in any way. As you have a big temperature difference between the radiator bottom and top (cooler top), it looks very much like no-flow, i.e. bad water pump. The coolant flow is from the radiator bottom to top and, if there is no flow, the temp-switch does not get hot enough coolant to trigger it. The fact that you can bleed the system does not mean that the pump must be good; the coolant will flowing out of the bleed nipples even if the pump is bad as it will be pushed by the cooling system pressure created when the coolant heats up.
  19. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Miroljub, didn't some 348 water pumps have plastic impellers?
  20. m.stojanovic
    3,289
    Serbia - Niš
    Miroljub Stojanovic
    According to what I have read (and seen pictures of cracked/loose impellers), the 348 pumps did have plastic impellers as factory installed. Perhaps up to a certain year or maybe all (can't remember finding anything about this). Some rebuilders offer the pump with a steel impeller. I do have a new pump at home (from Eurospares, aftermarket I think) and I will check what impeller it has and inform.
  21. m.stojanovic
    3,289
    Serbia - Niš
    Miroljub Stojanovic
    #21 m.stojanovic, May 11, 2016
  22. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Thought I remembered seeing something about plastic impellers on those pumps. it was tough for me to get a handle on everything the OP was saying but it sure sounded like the pump wasn't circulating water, which is a more reasonable assumption where there is a possibility that a plastic impeller was used. Thanks for the info. Hope things are going well for you.
  23. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    Well it's the water pump for sure. Took out the therm. And started the eng. no water at all out of the pump. Ughhhhhhhhhh. Now I'm trying to fig. On an elect. Water pump to get me thru the summer. Prob. A billet alum. Race pump. 50gph should be ok. I think???? Any thoughts guys.
  24. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,629
    San Carlos, CA
    Mitchell Le
    What alternatives do you have other than buying a new pump, pulling the engine, and replacing the pump again?
  25. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    If the fans aren't kicking on the first thing I would check would be the temp sender (aka: temperature switch, part number 158655) on the half radiator, on the right hand side of the engine bay, just above the oil cooler. The sender will be on the top left corner of the half radiator.
